# Audio quality is different when building Unity project using FMOD integration and Unity Audio
**URL:** <https://qa.fmod.com/t/audio-quality-is-different-when-building-unity-project-using-fmod-integration-and-unity-audio/20513>\
**Tags:** android, unity\
**Created:** [August 8, 2023, 12:49pm UTC](https://qa.fmod.com/t/audio-quality-is-different-when-building-unity-project-using-fmod-integration-and-unity-audio/20513 "2023-08-08T12:49:47Z")\
**Showing post:** 16
**Post date:** [September 7, 2023, 6:29am UTC](https://qa.fmod.com/t/audio-quality-is-different-when-building-unity-project-using-fmod-integration-and-unity-audio/20513/16 "2023-09-07T06:29:23Z")
After some investigation, it seems that this issue is linked to a previous forum post here: [Volume difference between Audio APIs - #2 by jeff\_fmod](https://qa.fmod.com/t/volume-difference-between-audio-apis/19298/2).
Unfortunately, we are not able to solve the issue at this time. A workaround may be changing the output used by the FMOD core system to OpenSL.
I would recommend using the [Unity Integration | Scripting Examples - Callback Handler](https://fmod.com/docs/2.02/unity/examples-callback-handler.html) to change the output before the FMOD system initializes. To change the output you need to call [FMOD Engine | Core API Reference - System::setOutput](https://fmod.com/docs/2.02/api/core-api-system.html#system_setoutput).
Hope this helps.
_[View the full topic](https://qa.fmod.com/t/audio-quality-is-different-when-building-unity-project-using-fmod-integration-and-unity-audio/20513)._
