Build ATRAC9 banks using command line tool
(Anton) #1
I cannot build my .fsb files in atrac9 format via fmod_designercl.exe. Docs and command line help say I should use -at9, or -c at9 options, but they both don’t work.
-at9 - ignored, all is compressed in PCM
-c at9 - says unknown format is specified
What do I do wrong way?
Thanks.
(Mathew Block) #2
Can you confirm you have the at9 encoder DLL in the same directory as Designer?
(Anton) #3
Yes, I have it. It is loaded as a process module (I checked it using Visual Studio attach to process).
(Mathew Block) #4
The command line for newer versions of Designer is -c “ps4 at9”, can you try this?
(Anton) #5
It works, thanks a lot for the help.
(Mathew Block) #6
Newer versions of Designer use the following command line:
-c "ps4 at9"
