# Build issue
**URL:** <https://qa.fmod.com/t/build-issue/22825>\
**Created:** [April 22, 2025, 7:50am UTC](https://qa.fmod.com/t/build-issue/22825 "2025-04-22T07:50:26Z")\
**Showing post:** 4
**Post date:** [April 24, 2025, 12:28am UTC](https://qa.fmod.com/t/build-issue/22825/4 "2025-04-24T00:28:59Z")
Thank you for the information.
There is a known issue with CI builds at the moment. A [workaround](https://qa.fmod.com/t/docker-windows-dllnotfoundexception-fmodstudiol/20491/36) is hard setting the auditioning system to [NOSOUND](https://fmod.com/docs/2.02/api/core-api-system.html#fmod_outputtype:~:text=System%3A%3AgetOutput%20only.-,FMOD_OUTPUTTYPE_NOSOUND,-All%20%2D%20Perform%20all). Could you please test updating the `EditorUtils.cs` underline `541`:
private static void CreateSystem()
    RuntimeUtils.DebugLog("FMOD Studio: Creating editor system instance");
    RuntimeUtils.EnforceLibraryOrder();
    FMOD.RESULT result = FMOD.Debug.Initialize(FMOD.DEBUG_FLAGS.LOG, FMOD.DEBUG_MODE.FILE, null, "fmod_editor.log");
    if (result != FMOD.RESULT.OK)
        RuntimeUtils.DebugLogWarning("FMOD Studio: Cannot open fmod_editor.log. Logging will be disabled for importing and previewing");
    CheckResult(FMOD.Studio.System.create(out system));
    FMOD.System lowlevel;
    CheckResult(system.getCoreSystem(out lowlevel));
    // New lines to force no sound
    CheckResult(lowlevel.setOutput(FMOD.OUTPUTTYPE.NOSOUND));
Please let me know if this allows builds to succeed. Note, that auditioning events in the Unity editor or in a timeline will not work with this change. For the change to be applied you can either build banks or delete the `FMODStudioSettings ` object.
Could I also please grab the `fmod_editor.log`? This should be found in your Unity project directory.
_[View the full topic](https://qa.fmod.com/t/build-issue/22825)._
