[C#] Dynamic DSP.setParameter
(launcher) #1
Hi, I want to play sound with effect.
In example, I’m using low and highpass, I want to set the parameters of two effect with the mouse location (x, y).
I used DSP.reset() and DSP.setParameter(), but, there is a problem.
If I moved the mouse faster and faster, the Sound is not smooth.
The original sound is played between time of the code reset() and setParameter() .
Therefore I can hear a sound like spark( ‘tick! tick!’).
I want to make it smooth.
Is there any way??
 private void mouse_effect_move(object sender, MouseEventArgs e)
            int i;
            i = e.Y / 10;
            dsplowpass.reset();
            dsphighpass.reset();
            if (i < 9)
                dsphighpass.setParameter(0, 6310 - 700 * i);
                //dsphighpass.setParameter(1, 1);
            else
                dsplowpass.setParameter(0, 22000 - 2200 * (i - 9));
                //dsplowpass.setParameter(1, 1);
(launcher) #2
its my current code.
(Mathew Block) #3
Using DSP::reset is usually reserved for when you are reusing a DSP on a different FMOD::Sound and you want to reset any state. You shouldn’t call it when you are simply updating parameters.
(launcher) #4
should I use DSP.remove ??
(Mathew Block) #5
No, the DSP::setParameter is sufficient on its own.
(launcher) #6
You mean do not use DSP::remove(), do use just DSP::setParameter?
(Mathew Block) #7
Yes
(launcher) #8
Thank you. I thought, the effect piled up when use just setParameter. I fixed thx.
