[c#] Monogame Help fmodex.dll
(Hans) #1
I can not put the fmodex dll inside the solution of the Visual Studio 2010 Express from my MonoGame?
(Brett Paterson) #2
Why do you want to put the dll in a visual studio solution? It should just be located in the same folder as your executable.
(Hans) #3
I do not think the library is accepting because it is c ++
(Brett Paterson) #4
if you have errors when you compile / link, you need to add the FMOD import library from the /lib folder. This would be added as a text entry in the linker settings for your project (ie linker->input->additional dependencies)
