# Can't launch built project, FMOD library not loaded
**URL:** <https://qa.fmod.com/t/cant-launch-built-project-fmod-library-not-loaded/14833>\
**Category:** Unreal Engine\
**Created:** [July 8, 2019, 10:36am UTC](https://qa.fmod.com/t/cant-launch-built-project-fmod-library-not-loaded/14833 "2019-07-08T10:36:25Z")\
**Author:** ![lionclop](https://avatars.discourse-cdn.com/v4/letter/l/bb73d2/32.png) [@lionclop](https://qa.fmod.com/u/lionclop)\
**Post date:** [July 9, 2019, 5:03am UTC](https://qa.fmod.com/t/cant-launch-built-project-fmod-library-not-loaded/14833/2 "2019-07-09T05:03:03Z")
Just found another answer from this post:
> [@4.22 MacOS Packaged Build crashes, cannot find libfmodL.dylib](https://qa.fmod.com/t/4-22-macos-packaged-build-crashes-cannot-find-libfmodl-dylib/14603/2):
> Are you able to share the logs from the game? You can send them to [support@fmod.com](mailto:support@fmod.com).
_[View the full topic](https://qa.fmod.com/t/cant-launch-built-project-fmod-library-not-loaded/14833)._
