# Can't record with Unity Recorder
**URL:** https://qa.fmod.com/t/cant-record-with-unity-recorder/18892
**Category:** Unity
**Tags:** unity
**Created:** [June 14, 2022, 1:22pm UTC](https://qa.fmod.com/t/cant-record-with-unity-recorder/18892 "2022-06-14T13:22:52Z")
**Showing post:** 9
### Author: ![fitzcheawell](https://avatars.discourse-cdn.com/v4/letter/f/ce73a5/32.png) [@fitzcheawell](https://qa.fmod.com/u/fitzcheawell)
#### Post date: [June 26, 2025, 12:11pm UTC](https://qa.fmod.com/t/cant-record-with-unity-recorder/18892/9 "2025-06-26T12:11:55Z")
Thanks for sharing, with a few modifications to your code i finally got the result. Put this script somewhere in a root or a start scene, fmod audio will be captured into audio source, but only when Unity Recorder is on (Time.captureFramerate != 0).
But you need to toggle “Allow unsafe” in the Player settings for this to be compiled, or use jeff\_fmod’s version of fmod read dsp callback, those changes are just for some performance to avoid array allocations.
using System;
using System.Runtime.CompilerServices;
using FMOD;
using FMODUnity;
using UnityEngine;
using Debug = UnityEngine.Debug;
namespace Recorder
    [RequireComponent(typeof(AudioSource))]
    public sealed class FmodRecorderHelper : MonoBehaviour
        private readonly List<float> _buffer = new();
        private DSP_DESCRIPTION _dspDesc;
        private DSP _dsp;
        private bool _isRunning = false;
        private bool _isCreatedDsp = false;
        private static bool _isInitialized = false;
        private void Awake()
            if (_isInitialized)
                Destroy(this);
                return;
            _isInitialized = true;
            DontDestroyOnLoad(this);
        private void Reset()
            var audioSource = GetComponent<AudioSource>();
            audioSource.spatialBlend = 0f;
            audioSource.reverbZoneMix = 0f;
        private void OnDestroy()
            RemoveDsp();
        private void OnAudioFilterRead(float[] data, int channels)
            if (!_isRunning) return;
            if (_buffer.Count >= data.Length)
                // Copy from intermediate buffer into Unity's audio buffer
                for (int i = 0; i < data.Length; i++)
                    data[i] = _buffer[i];
                _buffer.RemoveRange(0, data.Length);
        private void Update()
            if (Time.captureFramerate == 0)
                if (_isRunning) RemoveDsp();
                return;
            if (_isRunning) return;
            CreateDsp();
            RuntimeManager.CoreSystem.getMasterChannelGroup(out var group);
            if (group.hasHandle())
                _isRunning = true;
                CHECK_RESULT(group.addDSP(0, _dsp));
        private void CreateDsp()
            if (_isCreatedDsp) return;
            _isCreatedDsp = true;
            _dspDesc = new DSP_DESCRIPTION
                numinputbuffers = 1,
                numoutputbuffers = 1,
                read = (ref DSP_STATE dsp_state, IntPtr inbuffer, IntPtr outbuffer, uint length, int inchannels, ref int outchannels) =>
                    if (length > 0)
                        unsafe
                            // Copy to buffer
                            var tmp = new Span<float>(inbuffer.ToPointer(), (int) length * inchannels);
                            for (int i = 0; i < tmp.Length; i++)
                                _buffer.Add(tmp[i]);
                            // Silence FMOD output
                            tmp = new Span<float>(outbuffer.ToPointer(), (int) length * inchannels);
                                tmp[i] = 0f;
                    return RESULT.OK;
            var result = RuntimeManager.CoreSystem.createDSP(ref _dspDesc, out _dsp);
            var unitySpeakerMode = AudioSettings.GetConfiguration().speakerMode;
            var speakerMode = unitySpeakerMode switch
                AudioSpeakerMode.Mono => SPEAKERMODE.MONO,
                AudioSpeakerMode.Stereo => SPEAKERMODE.STEREO,
                AudioSpeakerMode.Quad => SPEAKERMODE.QUAD,
                AudioSpeakerMode.Surround => SPEAKERMODE.SURROUND,
                AudioSpeakerMode.Mode5point1 => SPEAKERMODE._5POINT1,
                AudioSpeakerMode.Mode7point1 => SPEAKERMODE._7POINT1,
                AudioSpeakerMode.Prologic => SPEAKERMODE.DEFAULT,
                _ => SPEAKERMODE.DEFAULT,
            int numChannels = unitySpeakerMode switch
                AudioSpeakerMode.Mono => 1,
                AudioSpeakerMode.Stereo => 2,
                AudioSpeakerMode.Quad => 4,
                AudioSpeakerMode.Surround => 5,
                AudioSpeakerMode.Mode5point1 => 6,
                AudioSpeakerMode.Mode7point1 => 7,
                AudioSpeakerMode.Prologic => 2,
                _ => 2,
            _dsp.setChannelFormat(CHANNELMASK.STEREO, numChannels, speakerMode);
            CHECK_RESULT(result);
        private void RemoveDsp()
            _isRunning = false;
            if (!_isCreatedDsp) return;
            CHECK_RESULT(RuntimeManager.CoreSystem.getMasterChannelGroup(out var group));
            CHECK_RESULT(group.removeDSP(_dsp));
            CHECK_RESULT(_dsp.release());
        private static void CHECK_RESULT(RESULT result, [CallerLineNumber] int sourceLineNumber = 0)
            if (result == RESULT.OK) return;
            Debug.LogError($"Call to FMOD API failed with result: \"{Error.String(result)}\" line: {sourceLineNumber}");
_[View the full topic](https://qa.fmod.com/t/cant-record-with-unity-recorder/18892)._
