Creating multichannel WAV files with more than 8 channels?
(NotVeryLoud) #1
Is anyone creating multichannel audio files that have more than 8 channels? (4 x stereo, or 7.1 setups).
And if so, how are you creating them? Sony Sound Forge seems limited to 8 mono channels. The program “wavewizard” mentioned in the FMOD manual is no longer available.
(Guest) #2
Wavosaur is pretty good for creating mutlichannel files.
(Mathew Block) #3
Sound Forge 9.0 and above should be able to create multichannel wav files (up to 32 channels). As Pete mentioned, Wavosaur can get the job done, as can Audacity.
(NotVeryLoud) #4
Thanks. When creating a New File, SoundForge seems limited to a set of multichannel presets that only go up to a 7.1 arrangement (8 mono).
As far as I can tell, you can’t just enter an arbitrary number of channels.
Recently downloaded wavosaur. Never even thought of trying Audacity.
Thanks for the suggestions.
(Mathew Block) #5
With Sound Forge 9.0 there is a drop down for the channel count which goes up to 7.1, but you can type any value in. Perhaps this is different in your version of Sound Forge?
(NotVeryLoud) #6
Well, what do you know :slight_smile: Just tried it, and yeah, it worked.
Sometimes the answer is a little too obvious.
Many thanks.
