# Event Callbacks for different callback types
**URL:** <https://qa.fmod.com/t/event-callbacks-for-different-callback-types/21806>\
**Created:** [June 25, 2024, 5:13pm UTC](https://qa.fmod.com/t/event-callbacks-for-different-callback-types/21806 "2024-06-25T17:13:29Z")\
**Author:** ![li\_fmod](https://yyz2.discourse-cdn.com/flex036/user_avatar/qa.fmod.com/li_fmod/32/6577_2.png) [@li\_fmod](https://qa.fmod.com/u/li_fmod)\
**Post date:** [June 28, 2024, 3:52am UTC](https://qa.fmod.com/t/event-callbacks-for-different-callback-types/21806/2 "2024-06-28T03:52:07Z")
Thank you for sharing the code.
> [@spakment](#):
> Is it possible to setup multiple callbacks on events,
> eg different callbacks for differnt EVENT\_CALLBACK\_TYPEs?
> Or is it only possible to have a single callback on an event?
It is indeed possible to set up multiple callbacks flags on the same event instance. I would suggest you to have a look at a similar post which I will link here:
> [@(C#) Calling EventInstance::setCallback with various callbackmasks results in only the last one working](https://qa.fmod.com/t/c-calling-eventinstance-setcallback-with-various-callbackmasks-results-in-only-the-last-one-working/12610/2):
> There can only be one callback delegate registered per event. If you wish to receive multiple types of events OR them together. instance.setCallback(m\_delegate1, EVENT\_CALLBACK\_TYPE.STOPPED | EVENT\_CALLBACK\_TYPE.CREATED); The specific event that triggered the callback is passed as an argument.
Hope it helps, let me know if you have any questions.
_[View the full topic](https://qa.fmod.com/t/event-callbacks-for-different-callback-types/21806)._
