# Example code for Programmer Instruments doesn't work. "Loading Delay Exceeded"
**URL:** <https://qa.fmod.com/t/example-code-for-programmer-instruments-doesnt-work-loading-delay-exceeded/19025>\
**Created:** [July 19, 2022, 1:33pm UTC](https://qa.fmod.com/t/example-code-for-programmer-instruments-doesnt-work-loading-delay-exceeded/19025 "2022-07-19T13:33:55Z")\
**Author:** ![SoftwareGeezers](https://avatars.discourse-cdn.com/v4/letter/s/aca169/32.png) [@SoftwareGeezers](https://qa.fmod.com/u/SoftwareGeezers)\
**Post date:** [July 20, 2022, 9:14am UTC](https://qa.fmod.com/t/example-code-for-programmer-instruments-doesnt-work-loading-delay-exceeded/19025/2 "2022-07-20T09:14:10Z")
Additionally, seen the related post about player modifiable audio here and followed:
> [@General advice on user-friendly process for players to upload audio assets then pipe them through FMOD-powered Unity?](https://qa.fmod.com/t/general-advice-on-user-friendly-process-for-players-to-upload-audio-assets-then-pipe-them-through-fmod-powered-unity/19005/2):
> Hi, An option you have is using Programmer Instrument, explained in the [Glossary](https://fmod.com/docs/2.02/studio/glossary.html#programmer-instrument). These allow for files outside of the FMOD and game project files to be used as audio sources. You will need to include: using System; and using System.Runtime.InteropServices; at the top of your code file. Create an FMODUnity.EventReference variable which will be used to instantiate your [Programmer Instrument](https://fmod.com/docs/2.02/studio/working-with-instruments.html#programmer-instruments) from the FMOD Project. Then create an [FMOD.Studio.EVENT\_CALLBACK](https://fmod.com/docs/2.02/api/studio-api-eventinstance.html#fmod_studio_event_callback) variable which will be used to create …
Followed that to produce this code. I have “sound1.wav” in Assets/StreamingAssets. This code produces the error:
> [FMOD] SoundSourceInstrumentInstance::startChannelIfReady : Waveform instance in error state 18
using System;
using UnityEngine;
public class eatme : MonoBehaviour {
	FMOD.Studio.EVENT_CALLBACK soundCallback;
	public FMODUnity.EventReference programmerSoundEventRef;
	// Start is called before the first frame update
	void Start() {
		soundCallback = new FMOD.Studio.EVENT_CALLBACK(PlayFileCallBack);
	[AOT.MonoPInvokeCallback(typeof(FMOD.Studio.EVENT_CALLBACK))]
	static FMOD.RESULT PlayFileCallBack(FMOD.Studio.EVENT_CALLBACK_TYPE type, IntPtr instancePtr, IntPtr parameterPtr) {
		FMOD.Studio.EventInstance instance = new FMOD.Studio.EventInstance(instancePtr);
		if (instance.isValid() == false) {
			UnityEngine.Debug.Log("Failed to create instance, instance invalid");
			return FMOD.RESULT.ERR_EVENT_NOTFOUND;
		//Retrive the user data
		IntPtr stringPtr;
		instance.getUserData(out stringPtr);
		// Retrieving the path of the audio source from the user data
		GCHandle stringHandle = GCHandle.FromIntPtr(stringPtr);
		String location = stringHandle.Target as String;
		switch (type) {
			case FMOD.Studio.EVENT_CALLBACK_TYPE.CREATE_PROGRAMMER_SOUND: {
				FMOD.MODE soundMode = FMOD.MODE.LOOP_NORMAL | FMOD.MODE.CREATECOMPRESSEDSAMPLE | FMOD.MODE.NONBLOCKING;
				var parameter = (FMOD.Studio.PROGRAMMER_SOUND_PROPERTIES)Marshal.PtrToStructure(parameterPtr, typeof(FMOD.Studio.PROGRAMMER_SOUND_PROPERTIES));
				FMOD.Sound audioSound;
				FMOD.RESULT result;
				// Creating the sound using the location of the audio source
				result = FMODUnity.RuntimeManager.CoreSystem.createSound(location, soundMode, out audioSound);
				if (result == FMOD.RESULT.OK) {
					parameter.sound = audioSound.handle;
					parameter.subsoundIndex = -1;
					Marshal.StructureToPtr(parameter, parameterPtr, false);
				break;
			case FMOD.Studio.EVENT_CALLBACK_TYPE.DESTROY_PROGRAMMER_SOUND: {
				var paramerter = (FMOD.Studio.PROGRAMMER_SOUND_PROPERTIES)Marshal.PtrToStructure(parameterPtr, typeof(FMOD.Studio.PROGRAMMER_SOUND_PROPERTIES));
				var sound = new FMOD.Sound(paramerter.sound);
				sound.release();
				break;
			case FMOD.Studio.EVENT_CALLBACK_TYPE.DESTROYED: {
				// Now the event has been destroyed, unpin the string memory so it can be garbaged collected
				stringHandle.Free();
				break;
		return FMOD.RESULT.OK;
	public void PlayAudioFile(string location) {
		var eventInstance = FMODUnity.RuntimeManager.CreateInstance(programmerSoundEventRef);
		// FMOD.RESULT is a very useful debugging tool to ensure that FMOD functions have run properly
		FMOD.RESULT result;
		if (eventInstance.isValid() == false) {
			return;
		// Lock the file location in memory to be used in the CALLBACK function to find the audio source
		GCHandle stringLocation = GCHandle.Alloc(location);
		// Assigning this data to the created instance
		result = eventInstance.setUserData(GCHandle.ToIntPtr(stringLocation));
		// Using an if statement like this after most FMOD function calls will help debug errors in code
		if (result != FMOD.RESULT.OK) {
			Debug.Log("Failed to create evenInstance with result of " + result);
			return;
		// Check the result after each function call
		result = eventInstance.setCallback(soundCallback);
		result = eventInstance.start();
		result = eventInstance.release();
		// The sound has successfully been created and played
	void Update() {
		if (Input.GetKeyDown(KeyCode.Alpha1)) {
			PlayAudioFile("sound1.wav");
_[View the full topic](https://qa.fmod.com/t/example-code-for-programmer-instruments-doesnt-work-loading-delay-exceeded/19025)._
