External VST
(In gyu, Oh) #1
Is it possible to use and include an external VST on the final build ?
I have being using the 4.44.36 version
Can get the final build output using an external plug-in(.dll)?
(Administrator) #2
Yes , you can use System::loadPlugin, System::createDSP and then then System::addDSP to insert it at the end of the signal chain.
VST is typically only stereo so you will probably have to use FMOD_SPEAKERMODE_STEREO with System:setSpeakerMode
