# Failed to build bank "master" due to the following error: File not found problem
**URL:** <https://qa.fmod.com/t/failed-to-build-bank-master-due-to-the-following-error-file-not-found-problem/17029>\
**Created:** [April 12, 2021, 11:09am UTC](https://qa.fmod.com/t/failed-to-build-bank-master-due-to-the-following-error-file-not-found-problem/17029 "2021-04-12T11:09:11Z")\
**Showing post:** 11
**Author:** ![Zajcyk](https://yyz2.discourse-cdn.com/flex036/user_avatar/qa.fmod.com/zajcyk/32/592_2.png) [@Zajcyk](https://qa.fmod.com/u/Zajcyk)\
**Post date:** [August 5, 2021, 5:15pm UTC](https://qa.fmod.com/t/failed-to-build-bank-master-due-to-the-following-error-file-not-found-problem/17029/11 "2021-08-05T17:15:26Z")
I had that same issue and when i fill all convolution reverb its resolved.
_[View the full topic](https://qa.fmod.com/t/failed-to-build-bank-master-due-to-the-following-error-file-not-found-problem/17029)._
