FMOD Event System Error on WP8
#1
I use the following code to init FMOD.
unsigned int     version;
int              numdrivers;
FMOD_SPEAKERMODE speakermode;
FMOD_CAPS        caps;
FMOD_RESULT result = FMOD::EventSystem_Create(&m_EventSystem);
FMOD_ERR_CHECK(result);
result = m_EventSystem->getSystemObject(&m_System);
result = m_System->getVersion(&version);
if (version < FMOD_VERSION)
	printf("Error!  You are using an old version of FMOD %08x.  This program requires %08x\n", version, FMOD_VERSION);
	return;
result = m_System->getNumDrivers(&numdrivers);
if (numdrivers == 0)
	result = m_System->setOutput(FMOD_OUTPUTTYPE_NOSOUND);
result = m_System->setDSPBufferSize(2048, 4);
m_System->setFileSystem(FMOD_FILE_OPENCALLBACK, FMOD_FILE_CLOSECALLBACK, FMOD_FILE_READCALLBACK, FMOD_FILE_SEEKCALLBACK, NULL, NULL, 1024 * 256);
result = m_System->init(32, FMOD_INIT_NORMAL, 0);
And here is the init log.
FMOD: OutputWASAPI::enumerate : Enumerating…
FMOD: OutputWASAPI::enumerate : Done.
FMOD: SystemI::init : FMOD Ex Version: 00044440
FMOD: SystemI::init : maxchannels = 32, flags = 00000000, extradriverdata = 00000000
FMOD: SystemI::close :
FMOD: SystemI::close : Stop all sounds
FMOD: SystemI::close : Shut down output.
FMOD: OutputWASAPI::close : Closing…
FMOD: OutputWASAPI::close : Done.
FMOD: SystemI::close : Remove miscllaneous DSP stuff.
FMOD: SystemI::close : done.
FMOD: OutputWASAPI::initEx : Initialising…
FMOD: OutputWASAPI::initEx : Done.
FMOD: SystemI::init : Set up software engine
FMOD: Thread::initThread : Initializing FMOD (WASAPI) feeder thread. priority 1
FMOD: Thread::initThread : - Stacksize 0. Stack pointer 00000000 : usesemaphore = 0 : sleeptime = 0
FMOD: Thread::callback : * FMOD (WASAPI) feeder thread started
FMOD: Thread::initThread : done.
FMOD: Thread::initThread : Initializing FMOD mixer thread. priority 2
FMOD: Thread::initThread : - Stacksize 49152. Stack pointer 00000000 : usesemaphore = 1 : sleeptime = 0
FMOD: Thread::callback : * FMOD mixer thread started
FMOD: SystemI::init : Set up emulated output
FMOD: SystemI::init : create the channel pool
FMOD: SystemI::init : Set up streamer
FMOD: Thread::initThread : Initializing FMOD stream thread. priority 2
FMOD: Thread::initThread : - Stacksize 65536. Stack pointer 00000000 : usesemaphore = 0 : sleeptime = 10
FMOD: Thread::callback : * FMOD stream thread started
FMOD: SystemI::init : done
when I called any method of FMOD::EventSystem (eg. getCategory, load) and received:
FMOD error! (31) FMOD was not initialized correctly to support this function.
I used the fev, fsb file that were used in ios and android.
Did something i miss?
thx!
#2
You need to call EventSystem::Init() not System::Init().
