# Fmod Master.strings bank is not Valid
**URL:** https://qa.fmod.com/t/fmod-master-strings-bank-is-not-valid/22992
**Category:** FMOD Studio
**Tags:** unity
**Created:** [May 30, 2025, 7:47pm UTC](https://qa.fmod.com/t/fmod-master-strings-bank-is-not-valid/22992 "2025-05-30T19:47:51Z")
### Author: ![li\_fmod](https://yyz2.discourse-cdn.com/flex036/user_avatar/qa.fmod.com/li_fmod/32/6577_2.png) [@li\_fmod](https://qa.fmod.com/u/li_fmod)
#### Post date: [June 2, 2025, 3:55am UTC](https://qa.fmod.com/t/fmod-master-strings-bank-is-not-valid/22992/2 "2025-06-02T03:55:55Z")
Thank you for sharing the information and version number.
> [@Diego576](#):
> Unity says that Master.string.bank is not a valid bank.
This error is often caused by a version mismatch between FMOD Studio and the Unity FMOD integration. Could you please check the version of your FMOD Unity plugin? You can find this information by navigating to **FMOD \> About Integration** in the Unity menu.
 ![image](https://canada1.discourse-cdn.com/flex036/uploads/fmod/original/2X/c/c933216076997d3137325478faa1ea42f124fab6.png)
 ![image](https://canada1.discourse-cdn.com/flex036/uploads/fmod/original/2X/4/43b54bd8c6ccfe778d9b6dd28136be1596707060.png)
Additionally, there’s a similar discussion that might help you resolve the issue: [Master.strings.bank is not a valid bank - #5 by jeff\_fmod](https://qa.fmod.com/t/master-strings-bank-is-not-a-valid-bank/17323/5)
Hope this helps! Let me know if the issue persists.
_[View the full topic](https://qa.fmod.com/t/fmod-master-strings-bank-is-not-valid/22992)._
