FMOD on linux on CLion
#1
I’ve used FMOD on windows using visual studio. Adding FMOD library to the project was quite easy but I can’t find how to add FMOD to the project on CLion (linux), I know that I have to use CMake but no idea how to.
Any help would be appreciated.
G.G
#2
Unfortunately I am not familiar with CLion, perhaps someone else here can assist in that regard.
I’d recommend taking a look at our example Makefiles in our Linux SDK. The flags they use are likely the same what you’ll need for CLion.
The basics are usually:
-I[include_path]
-L[library_path]
-l[fmod]
EDIT:
Based on your response, it looks like CMake syntax, so you will probably need to use the following commands:
link_directories([library_path])
include_directories([include_path])
target_link_libraries(<target>, [fmod_library_name])
I found this information here.
#3
Thank you so much Mathew it worked for me. just one note, I have to replace “fmod_library_name” in the “target_link_libraries” by the library_path+library name.
#4
Hi Mathew:
Thank you for your reply,
I already figured out how to add include and lib directories, it can be done as follows:
# Add extra include directories
include_directories(/../../fmodstudioapi10812linux/api/lowlevel/inc)
include_directories(/../../fmodstudioapi10812linux/api/studio/inc)
# Add extra lib directories
include_directories(/home/golnaz/fmodstudioapi10812linux/api/lowlevel/lib)
include_directories(/home/golnaz/fmodstudioapi10812linux/api/studio/lib)
I know that I also have to include a few more lines like “findPackage” and “set” but I don’t know how to.
I appreciate any help from you or anyone else with more information.
G.G
#5
I’ve added some additional information to my response based on your extra info.
