# FMOD\_OS\_Net\_Listen : Cannot listen for connections, port 9264 is currently in use
**URL:** <https://qa.fmod.com/t/fmod-os-net-listen-cannot-listen-for-connections-port-9264-is-currently-in-use/24048>\
**Created:** [February 18, 2026, 7:30am UTC](https://qa.fmod.com/t/fmod-os-net-listen-cannot-listen-for-connections-port-9264-is-currently-in-use/24048 "2026-02-18T07:30:36Z")\
**Post date:** [February 23, 2026, 5:07am UTC](https://qa.fmod.com/t/fmod-os-net-listen-cannot-listen-for-connections-port-9264-is-currently-in-use/24048/2 "2026-02-23T05:07:53Z")
Your Unity instance is trying to connect to [FMOD Studio | Glossary - Live Update](https://fmod.com/docs/2.03/studio/glossary.html#live-update).
[FMOD Studio | Editing During Live Update](https://fmod.com/docs/2.03/studio/editing-during-live-update.html)
Live update can be disabled in the platform settings: [Unity Integration | Settings - Live Update](https://fmod.com/docs/2.03/unity/settings.html#live-update), which will stop the Unity integration trying to connect to your FMOD Studio Instance.
If you want to connect to the studio instance I would suggest following these steps: [Issue with Live Connecting in 2.02.15 - #2 by Leah\_FMOD](https://qa.fmod.com/t/issue-with-live-connecting-in-2-02-15/20505/2) .
Or restarting you PC should help too.
Bank refresher just checks for changes to the bank files on disk and is not related to the warning.
Hope this helps
_[View the full topic](https://qa.fmod.com/t/fmod-os-net-listen-cannot-listen-for-connections-port-9264-is-currently-in-use/24048)._
