# FMODStudioCache.asset being changed in Unity Version Control
**URL:** <https://qa.fmod.com/t/fmodstudiocache-asset-being-changed-in-unity-version-control/23898>\
**Created:** [January 15, 2026, 11:41am UTC](https://qa.fmod.com/t/fmodstudiocache-asset-being-changed-in-unity-version-control/23898 "2026-01-15T11:41:15Z")\
**Showing post:** 4
**Author:** ![li\_fmod](https://yyz2.discourse-cdn.com/flex036/user_avatar/qa.fmod.com/li_fmod/32/6577_2.png) [@li\_fmod](https://qa.fmod.com/u/li_fmod)\
**Post date:** [January 30, 2026, 3:58am UTC](https://qa.fmod.com/t/fmodstudiocache-asset-being-changed-in-unity-version-control/23898/4 "2026-01-30T03:58:05Z")
> [@lynn\_osiviso](#):
> So even without FMODStudioCache.asset, everyone working on the Unity project should be able to hear the updated sounds?
Yes, even without FMODStudioCache.asset, everyone working on the Unity project should still be able to hear the updated sounds, as long as the FMOD banks themselves are built and available. The cache file is only used locally by the Unity Editor and is not required for audio playback.
> I assume I didn’t remove it correctly from the source control (because of the littering). Would it still be possible to remove it even though other project members have committed it before?
Yes, it is still possible to remove FMODStudioCache.asset from source control even if it was committed previously by other team members. Once the file is no longer tracked, it can remain local-only and be regenerated per user.
There is a similar discussion covering this behaviour in Unity Version Control / Plastic here: [FMOD.log keeps checking in ignored files in Unity PlasticSCM Source Control - #3 by Connor\_FMOD](https://qa.fmod.com/t/fmod-log-keeps-checking-in-ignored-files-in-unity-plasticscm-source-control/19359/3)
_[View the full topic](https://qa.fmod.com/t/fmodstudiocache-asset-being-changed-in-unity-version-control/23898)._
