# FSBank init problem
**URL:** <https://qa.fmod.com/t/fsbank-init-problem/18817>\
**Category:** FMOD Engine\
**Tags:** cpp\
**Created:** [May 30, 2022, 7:35am UTC](https://qa.fmod.com/t/fsbank-init-problem/18817 "2022-05-30T07:35:01Z")\
**Post date:** [June 2, 2022, 1:37am UTC](https://qa.fmod.com/t/fsbank-init-problem/18817/2 "2022-06-02T01:37:44Z")
Linking in this case: [FSBank Conversion of wav to fsb5 problem - #10 by CreatorsStudio](https://qa.fmod.com/t/fsbank-conversion-of-wav-to-fsb5-problem/18803/10)
This should initialize FSBank correctly- though I’m assuming `const char* cache = G:/cache;` is a formatting error / typo, and it is actually `const char* cache = "G:/cache";`, otherwise it won’t compile at all.
If it fails, you can investigate by passing the returned `FSBANK_RESULT` of an FSBank API calls into `FSBank_Result_ToString`.
_[View the full topic](https://qa.fmod.com/t/fsbank-init-problem/18817)._
