# GetLength from Event with Parameter
**URL:** <https://qa.fmod.com/t/getlength-from-event-with-parameter/22878>\
**Tags:** unity, csharp\
**Created:** [May 4, 2025, 1:41pm UTC](https://qa.fmod.com/t/getlength-from-event-with-parameter/22878 "2025-05-04T13:41:47Z")\
**Author:** ![li\_fmod](https://yyz2.discourse-cdn.com/flex036/user_avatar/qa.fmod.com/li_fmod/32/6577_2.png) [@li\_fmod](https://qa.fmod.com/u/li_fmod)\
**Post date:** [May 7, 2025, 2:40am UTC](https://qa.fmod.com/t/getlength-from-event-with-parameter/22878/2 "2025-05-07T02:40:20Z")
Thank you for sharing the information and screenshot.
> [@DeqafStudio](#):
> This code works fine for simple event, but event with Parameter return 0.
[Studio::EventDescription::getLength](https://www.fmod.com/docs/2.03/api/studio-api-eventdescription.html#studio_eventdescription_getlength) only returns the length of the timeline. If your event doesn’t have any content placed directly on the timeline (e.g., it uses parameter sheets or instruments triggered by parameters), then this function will return 0.
There’s a similar discussion here: [EventDescription length always zero - #2 by Leah\_FMOD](https://qa.fmod.com/t/eventdescription-length-always-zero/20638/2)
If restructuring your event to use the timeline isn’t feasible, you might consider using the `SOUND_PLAYED` callback. This allows you to access the underlying `FMOD::Sound` object and retrieve its length during playback.
You can find more details and sample code in this thread:: [How to retrieve a sound total time/length/duration? - #4 by jeff\_fmod](https://qa.fmod.com/t/how-to-retrieve-a-sound-total-time-length-duration/19300/4)
Hope this helps, let me know if you have questions.
_[View the full topic](https://qa.fmod.com/t/getlength-from-event-with-parameter/22878)._
