# How to create gameplay that relies on audio input?
**URL:** <https://qa.fmod.com/t/how-to-create-gameplay-that-relies-on-audio-input/19812>\
**Created:** [February 1, 2023, 1:47am UTC](https://qa.fmod.com/t/how-to-create-gameplay-that-relies-on-audio-input/19812 "2023-02-01T01:47:23Z")\
**Post date:** [February 2, 2023, 12:29am UTC](https://qa.fmod.com/t/how-to-create-gameplay-that-relies-on-audio-input/19812/2 "2023-02-02T00:29:18Z")
Yes, you can! It will require two things.
Firstly, a script used to record mic input here: [General advice on user-friendly process for players to upload audio assets then pipe them through FMOD-powered Unity? - #6 by Connor\_FMOD](https://qa.fmod.com/t/general-advice-on-user-friendly-process-for-players-to-upload-audio-assets-then-pipe-them-through-fmod-powered-unity/19005/6).
Secondly, one of our [FMOD Unity Integration | Scripting Examples](https://fmod.com/docs/2.02/unity/examples-dsp-capture.html), outlines creating and capturing a DSP which draws the sound waveform but can be changed for your functionality.
Keep in mind, you will want to add the new `DSP` to the `sounds channel` which is part of the `micRecordSystem` not onto the `master channel group`. So any reference of
FMODUnity.RuntimeManage.CoreSystem
Should be replaced with
micRecordSystem
Any reference to the `Master Channel Group` replaced with the `sounds channel`.
If you need any more help setting this up let me know!
_[View the full topic](https://qa.fmod.com/t/how-to-create-gameplay-that-relies-on-audio-input/19812)._
