https streaming
(Igor) #1
Is it possible to stream sounds from a https… URL ?
Thanks in advance
(Brett Paterson) #2
Yes you can use https streaming. You just have to enter the address with https:// or https:\
regards,
(Igor) #3
Then I must be doing something else wrong. I am trying to stream a song from SoundCloud servers like this.
FMOD_System_CreateSound(system, https://api.soundcloud.com/tracks/230155983/stream, FMOD_CREATESTREAM | FMOD_HARDWARE | FMOD_LOOP_NORMAL, NULL, &sound)
system is pointer to an initialized FMOD_System.
The Url was provided by SoundCloud as a waypoint for streaming.
When I call FMOD_System_CreateSound like this, FMOD crashes. Can you maybe tell what I am doing wrong ?
(Brett Paterson) #4
What do you mean by it crashes? Do you have a callstack? Are you sure you’re not manipulating an uninitialized pointer somewhere maybe?
When I test it here createSound returns FMOD_ERR_HTTP_ACCESS, and winamp also gives an authentication error.
Can you give some more information?
