May I process a pcm buffer with some dsp and write to a mp4 file on android?
#1
#android#
I tried ‘record’ demo, the sound’s delay is too much to put in the video on some devices.
Is it exist some api that can process pcm buffer with dsp without record or play?
#2
Could you please say what you are trying to achieve with FMOD? If you don’t need to record, you can take a look at the dsp_custom example for pointers on how to add a DSP into your signal chain.
Thanks,
Richard
