# Merge conflict with github
**URL:** <https://qa.fmod.com/t/merge-conflict-with-github/21846>\
**Created:** [July 8, 2024, 11:05am UTC](https://qa.fmod.com/t/merge-conflict-with-github/21846 "2024-07-08T11:05:10Z")\
**Post date:** [July 8, 2024, 10:19pm UTC](https://qa.fmod.com/t/merge-conflict-with-github/21846/2 "2024-07-08T22:19:36Z")
If anyone is using a Mac on your team it may cause the pop-up:
> [@Repair FMOD Libraries warning still keeps showing after click repair button](https://qa.fmod.com/t/repair-fmod-libraries-warning-still-keeps-showing-after-click-repair-button/18213/8):
> The issue is that git is replacing the line endings of the Mac libs from \n to \r\n. Clicking repair when this popup appears will switch them back to \n, but it looks like git is still clobbering the line endings every time you pull. Deleting them if you don’t need them is one option, otherwise if you add \*.bundle text eol=lf to your .gitattributes file then the line endings of any .bundle files will remain as \n (line feeds).
Would it be possible to update your `.gitignore`? Both of these files `FMODStudioCache.asset`, `fmod_editor.log` should be ignored:
# Never ignore DLLs in the FMOD subfolder.
!/[Aa]ssets/Plugins/FMOD/**/lib/*
# Don't ignore images and gizmos used by FMOD in the Unity Editor.
!/[Aa]ssets/Gizmos/FMOD/*
!/[Aa]ssets/Editor Default Resources/FMOD/*
# Ignore the Cache folder since it is updated locally.
/[Aa]ssets/Plugins/FMOD/Cache/*
# Ignore bank files in the StreamingAssets folder.
/[Aa]ssets/StreamingAssets/**/*.bank
/[Aa]ssets/StreamingAssets/**/*.bank.meta
# If the source bank files are kept outside of the StreamingAssets folder then these can be ignored.
# Log files can be ignored.
fmod_editor.log
Let me know if the issue persists!
_[View the full topic](https://qa.fmod.com/t/merge-conflict-with-github/21846)._
