multi channel audio analysis
#1
I’m new to FMOD Ex.
I use 8 MIC and audio interface. and PC and audio interface is connected USB port.
I want to handle 8 channel, mono audio source and to analysis frequency domain in real time.
I would like to know whether I possible to use the FMOD Ex in visual C++.
just, I deal with 8 channel streaming input source at the same time.
#2
You have to record, and then play the sound at the same time to do any analysis on it. You could add an FFT DSP and get the spectrum in realtime as it plays.
To play it, you normally wait a few hundred ms after the recording was started, so the record cursor doesnt overwrite the play cursor and repeat/skip.
