# PulseAudio connection error in unit test on Linux
**URL:** <https://qa.fmod.com/t/pulseaudio-connection-error-in-unit-test-on-linux/21927>\
**Created:** [July 25, 2024, 12:41pm UTC](https://qa.fmod.com/t/pulseaudio-connection-error-in-unit-test-on-linux/21927 "2024-07-25T12:41:26Z")\
**Author:** ![Leah\_FMOD](https://yyz2.discourse-cdn.com/flex036/user_avatar/qa.fmod.com/leah_fmod/32/3685_2.png) [@Leah\_FMOD](https://qa.fmod.com/u/Leah_FMOD)\
**Post date:** [July 30, 2024, 2:38am UTC](https://qa.fmod.com/t/pulseaudio-connection-error-in-unit-test-on-linux/21927/2 "2024-07-30T02:38:31Z")
You appear to be running into a known issue with running FMOD on Linux systems with reduced audio services, which has already been passed on to the development team for further investigation. Another user who ran into the has posted a workaround here: [Getting PulseAudio dependency to work in Ubuntu Docker image - #2 by joeanderson](https://qa.fmod.com/t/getting-pulseaudio-dependency-to-work-in-ubuntu-docker-image/21897/2)
As well as a GitHub repo demonstrating the error and the workaround: [Getting PulseAudio dependency to work in Ubuntu Docker image - #4 by joeanderson](https://qa.fmod.com/t/getting-pulseaudio-dependency-to-work-in-ubuntu-docker-image/21897/4)
I would recommend giving that user’s workaround a try and seeing whether it resolves the issue for you.
_[View the full topic](https://qa.fmod.com/t/pulseaudio-connection-error-in-unit-test-on-linux/21927)._
