setPosition problem?
#1
I have been using FMODEX for some time now and have just come across an issue with Channel::setPosition().
The issue occurs when I have a wav file larger than 2GB (I know wav files have either a 2GB or 4GB limit depending on who you talk to). I load the file as a stream and this succeeds and the current info is available via fmod about the file (num channels, length, freq, etc.). It will also play fine.
However, if I try to setPosition(pos, FMOD_TIMEUNIT_MS) when pos puts the playhead beyond the 2GB file point the call fails with the error FMOD_ERR_FILE_BAD. If I setPosition() to locations < 2GB limit it is fine. It will also play past the 2GB point fine.
I would really like this to work for me (up to the 4GB limit of the file type) since I have 16 channels of audio at 16bit PCM and I need files to be > 30mins in length.
Any thoughts?
Thanks.
#2
heh ok I knew this day would probably come when people started breaking the boundaries of signed 32bit integers :slight_smile:
I’ll look into it soon.
#3
Thanks Brett.
Glad to have been the one that bought that day closer :wink:
#4
Do you have any updates on it?
Tested on recent 11005 version low-level API, the problem still exists.
#5
I’m guessing that was FMOD Ex all that time ago.
Since then we switched the OS level seek to win32 setFilePointer which inherently doesn’t do >2gb seeks properly unless you specify the high part of a 64bit number as well.
I’ve updated this and it should work from now on. I’ve patched it for the next point release of 1.9 and 1.10
