# UE4.25.3 does not work with Fmod integration
**URL:** <https://qa.fmod.com/t/ue4-25-3-does-not-work-with-fmod-integration/16059>\
**Category:** Unreal Engine\
**Created:** [August 8, 2020, 10:48am UTC](https://qa.fmod.com/t/ue4-25-3-does-not-work-with-fmod-integration/16059 "2020-08-08T10:48:52Z")\
**Showing post:** 3
**Author:** ![mathew](https://yyz2.discourse-cdn.com/flex036/user_avatar/qa.fmod.com/mathew/32/431_2.png) [@mathew](https://qa.fmod.com/u/mathew)\
**Post date:** [August 13, 2020, 10:43pm UTC](https://qa.fmod.com/t/ue4-25-3-does-not-work-with-fmod-integration/16059/3 "2020-08-13T22:43:36Z")
Can you make sure there isn’t a mix-up between “+” and non “+” versions as detailed here:
> [@What's the latest stable Unreal Engine build for FMOD?](https://qa.fmod.com/t/whats-the-latest-stable-unreal-engine-build-for-fmod/16077/2):
> Please make sure when you download the FMOD for UE4 integration you are getting the correct version of UE4. Note 4.25 and 4.25+ are two separate incompatible branches of UE4. We are working to make this clearer on the website as many people are unaware of 4.25+ and mistakenly use it with 4.25. Perhaps this is your issue?
_[View the full topic](https://qa.fmod.com/t/ue4-25-3-does-not-work-with-fmod-integration/16059)._
