check the parameterValue in console
(DAVID CLADERA) #1
Hi, i would like to check that the parameterValue on trigger enter and triggerExit, is correct. I would like to see in the console with Debug.Log. But i can’t
void OnTriggerEnter (Collider hit){
	if (hit.GetComponent<Collider> ().CompareTag ("Player")) {
		MusicaC.mcaparam.setValue (0.12f);
		MusicaC.M_Pipes.getParameter ("MUSIC", out MusicaC.mcaparam);
		Debug.Log (MusicaC.mcaparam);
The number that appear in console is 0,why???
thanks
(Cameron Baron) #2
It looks as though you are resetting the parameter reference rather than the value.
Start()
    // Use this once to assign a reference to the parameter.
OnTriggerEnter()
        // Get the value of the paramter at this moment in time.
        MusicaC.mcaparam.getValue (out paramValue);
        if (paramValue == number)
