I installed FMOD Studio Version 1.03.04 on my 13" MPB OSX 10.7.4 - 2.3GHz Intel Core i5, 4GB 1333MHz DDR3, Intel HD 3000. I unpacked the .dmg and dragged the FMOD folder into my applications folder. I double click the FMOD app icon and FMOD started to load and then crashed. Below is the crash log. I looked to see if maybe an earlier version of FM Studio was recommended for OSX 10.7.4 but there doesn’t seem to be. Am I doing something wrong or else there a better version for me to use.
Process: fmodstudio [983]
Path: /Applications/FMOD Studio/FMOD Studio.app/Contents/MacOS/fmodstudio
Identifier: org.fmod.fmodstudio
Version: ??? (1.0)
Code Type: X86 (Native)
Parent Process: launchd [139]
Date/Time: 2014-04-13 22:38:49.611 +0100
OS Version: Mac OS X 10.7.4 (11E53)
Report Version: 9
Interval Since Last Report: 354953 sec
Crashes Since Last Report: 14
Per-App Interval Since Last Report: 41 sec
Per-App Crashes Since Last Report: 12
Anonymous UUID: 2BC35902-95C5-45E1-80D2-8E7D0831B091
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
–> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] —/--- SM=NUL /Applications/FMOD Studio/FMOD Studio.app/Contents/MacOS/fmodstudio
__TEXT 0000000000001000-0000000000c4b000 [ 12.3M] r-x/rwx SM=COW /Applications/FMOD Studio/FMOD Studio.app/Contents/MacOS/fmodstudio
Application Specific Information:
objc[983]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 ??? 0000000000 0 + 0
1 QtGui 0x01820c53 QMacPasteboardMime::~QMacPasteboardMime() + 1553
2 QtGui 0x0174a814 QApplicationPrivate::initializeWidgetPaletteHash() + 6380
3 QtGui 0x0174b760 QApplicationPrivate::initializeWidgetPaletteHash() + 10296
4 QtGui 0x017bc119 QApplicationPrivate::construct() + 217
5 QtGui 0x017bce7d QApplication::QApplication(int&, char**, bool, int) + 99
6 org.fmod.fmodstudio 0x000124a6 Application::Application(int&, char**) + 56
7 org.fmod.fmodstudio 0x0020c9ed main + 39
8 org.fmod.fmodstudio 0x00008df5 start + 53
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x911e990a kevent + 10
1 libdispatch.dylib 0x9caf9e10 _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x9caf885f _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x911e902e __workq_kernreturn + 10
1 libsystem_c.dylib 0x90d52ccf _pthread_wqthread + 773
2 libsystem_c.dylib 0x90d546fe start_wqthread + 30
Thread 3:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000009 ebx: 0x03c79a90 ecx: 0x9ce5940c edx: 0x00000016
edi: 0xbffff888 esi: 0x01820c2e ebp: 0xbffff7b8 esp: 0xbffff76c
ss: 0x00000023 efl: 0x00210282 eip: 0x00000000 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 2
Binary Images:
0x1000 - 0xc4afdb +org.fmod.fmodstudio (??? - 1.0) <824A88F1-C07E-3DB2-918A-85E2961C8DF5> /Applications/FMOD Studio/FMOD Studio.app/Contents/MacOS/fmodstudio
0x143d000 - 0x1489ffb com.apple.audio.midi.CoreMIDI (1.8 - 42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x14ac000 - 0x16ecfef +QtCore (4.7.4 - compatibility 4.7.0) <02E2942B-0D42-3A75-B5EB-CFAEF96E3A79> /Applications/FMOD Studio/FMOD Studio.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
0x1730000 - 0x2044fff +QtGui (4.7.4 - compatibility 4.7.0) <0A29E532-B580-3163-86F6-51DD341D3147> /Applications/FMOD Studio/FMOD Studio.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
0x216e000 - 0x227fff7 +QtNetwork (4.7.4 - compatibility 4.7.0) <531D447E-339E-369D-B287-C17B20BEBDC7> /Applications/FMOD Studio/FMOD Studio.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork
0x22a3000 - 0x22fffef +QtXml (4.7.4 - compatibility 4.7.0) /Applications/FMOD Studio/FMOD Studio.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
0x230f000 - 0x24c4fff +QtScript (4.7.4 - compatibility 4.7.0) /Applications/FMOD Studio/FMOD Studio.app/Contents/Frameworks/QtScript.framework/Versions/4/QtScript
0x8fe04000 - 0x8fe36aa7 dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
0x9000f000 - 0x90015ffb com.apple.print.framework.Print (7.4 - 247.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x90016000 - 0x90044ff7 com.apple.DictionaryServices (1.2.1 - 158.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x90045000 - 0x90046ff0 libunc.dylib (24.0.0 - compatibility 1.0.0) /usr/lib/system/libunc.dylib
0x9006c000 - 0x90086fff com.apple.Kerberos (1.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x90223000 - 0x9022aff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
0x9022b000 - 0x90250ff9 libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x90251000 - 0x902b5fff com.apple.framework.IOKit (2.0 - ???) <88D60E59-430D-35B8-B1E9-F5138301AEF9> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90547000 - 0x90949ff6 libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9094a000 - 0x9094cff7 libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
0x909a9000 - 0x90a66ff3 ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <726898F5-E718-3F27-B415-D6FDCDE09174> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x90a67000 - 0x90a7cff7 com.apple.ImageCapture (7.0.1 - 7.0.1) <1C8933A9-C7C6-36E9-9D8B-0EF08ACA3315> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x90a7d000 - 0x90a86fff libc++abi.dylib (14.0.0 - compatibility 1.0.0) /usr/lib/libc++abi.dylib
0x90a87000 - 0x90a87fff com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x90cf4000 - 0x90dbffff libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib
0x90e65000 - 0x90e70ffe libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
0x90e71000 - 0x90e79ff3 liblaunch.dylib (392.38.0 - compatibility 1.0.0) /usr/lib/system/liblaunch.dylib
0x90f1d000 - 0x90f22ffd libGFXShared.dylib (??? - ???) <1CA9B41B-2C61-38F8-ABAC-1D5511478F5C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x90f23000 - 0x90f8bff7 libc++.1.dylib (28.1.0 - compatibility 1.0.0) /usr/lib/libc++.1.dylib
0x9102b000 - 0x9102eff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x9102f000 - 0x910ffffb com.apple.ImageIO.framework (3.1.2 - 3.1.2) <94798A2B-4C7A-30EA-9920-283451BDB9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91100000 - 0x91110ff7 libCRFSuite.dylib (??? - ???) /usr/lib/libCRFSuite.dylib
0x911d0000 - 0x911eeff7 libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <3705DE40-E00F-3E37-ADB0-D4AE5F9950F5> /usr/lib/system/libsystem_kernel.dylib
0x911ef000 - 0x911f0ff4 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
0x9141e000 - 0x91421ff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
0x91422000 - 0x91423fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) /usr/lib/system/libsystem_blocks.dylib
0x91424000 - 0x91697ffb com.apple.CoreImage (7.98 - 1.0.1) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x91698000 - 0x9169cfff libGIF.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9169d000 - 0x916d9ffa libGLImage.dylib (??? - ???) <504E7865-571E-38B4-A84A-D7B513AC84F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x916da000 - 0x916dafff com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9175b000 - 0x9175ffff com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x917db000 - 0x917dbff2 com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x917ea000 - 0x91886fef com.apple.ink.framework (1.4 - 110) <1A3E2916-60C1-3AC1-86BF-202F6567B228> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x918a2000 - 0x918d9fef com.apple.DebugSymbols (2.1 - 87) /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x91933000 - 0x91936ffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
0x919c6000 - 0x91a9caab libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
0x91a9d000 - 0x91aa0ffb com.apple.help (1.3.2 - 42) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x91aa7000 - 0x91aa7fff com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91aae000 - 0x91bbdfff com.apple.DesktopServices (1.6.3 - 1.6.3) <18CAAA9E-7065-3FF7-ACFE-CDB60E5426A2> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91bbe000 - 0x91d20ffb com.apple.QuartzCore (1.7 - 270.4) <6BC84C60-1003-3008-ABE4-779EF7B4F524> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x91d25000 - 0x9264f59b com.apple.CoreGraphics (1.600.0 - ???) <62026E0C-E30F-3FF0-B0F6-6A2D270B20BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x92682000 - 0x92692fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x92693000 - 0x92776ff7 libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) /usr/lib/libcrypto.0.9.8.dylib
0x92777000 - 0x927b4ff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <1C757924-4E54-3522-A885-99795EA10228> /usr/lib/libcups.2.dylib
0x93132000 - 0x93132ffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
0x93133000 - 0x931c0ff7 com.apple.CoreText (220.20.0 - ???) <0C3EDD4F-6112-353A-8A3A-8D630182C22A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x931c2000 - 0x931c2fff com.apple.Carbon (153 - 153) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x931ec000 - 0x931edff7 libsystem_sandbox.dylib (??? - ???) /usr/lib/system/libsystem_sandbox.dylib
0x93214000 - 0x93265ff9 com.apple.ScalableUserInterface (1.0 - 1) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x938e2000 - 0x93905fff com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x93906000 - 0x9390dff9 libsystem_dnssd.dylib (??? - ???) /usr/lib/system/libsystem_dnssd.dylib
0x93915000 - 0x9399cfff com.apple.print.framework.PrintCore (7.1 - 366.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x93a14000 - 0x93a1fffc com.apple.NetAuth (1.0 - 3.0) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x93b68000 - 0x93b70ff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) /usr/lib/system/libunwind.dylib
0x94743000 - 0x94c1fff6 libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x94c20000 - 0x94c21ff7 libquarantine.dylib (36.6.0 - compatibility 1.0.0) <600909D9-BD75-386E-8D3E-7CBD29079DF3> /usr/lib/system/libquarantine.dylib
0x94c22000 - 0x94dd6ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
0x94ddf000 - 0x950e9ff3 com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x950ea000 - 0x95b7fff6 com.apple.AppKit (6.7.3 - 1138.47) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x95b80000 - 0x95c91ff7 libJP2.dylib (??? - ???) <845C74F4-1074-3983-945F-EB669538CAA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x95c92000 - 0x95d01fff com.apple.Heimdal (2.2 - 2.0) <2E1B8779-36D4-3C62-A67E-0034D77D7707> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x95d02000 - 0x95d60fff com.apple.coreui (1.2.2 - 165.10) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x95dda000 - 0x960dcfff com.apple.CoreServices.CarbonCore (960.24 - 960.24) <9692D838-85A5-32C1-B7FB-7C141FFC2557> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x96778000 - 0x9694ffe7 com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x96959000 - 0x9696efff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9696f000 - 0x96a05ff7 com.apple.LaunchServices (480.33 - 480.33) <5A4BF529-391E-3987-940E-287ACE56078A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x96f71000 - 0x96fceffb com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x972ff000 - 0x97361ff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
0x97362000 - 0x9737ffff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
0x97380000 - 0x97643fff com.apple.security (7.0 - 55148.1) <77754898-4FCD-3CA3-9339-F1058C852806> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x97644000 - 0x9766cff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) /usr/lib/libxslt.1.dylib
0x977f9000 - 0x97801fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9781b000 - 0x97913ff7 libFontParser.dylib (??? - ???) <1A0DA421-62B2-3AA7-9F62-0E01C1887D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x97938000 - 0x97939fff libDiagnosticMessagesClient.dylib (??? - ???) /usr/lib/libDiagnosticMessagesClient.dylib
0x9793d000 - 0x97951ff7 com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x97952000 - 0x9795dff3 libCSync.A.dylib (600.0.0 - compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x979a1000 - 0x979a5ffd IOSurface (??? - ???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x979a6000 - 0x979efff7 libGLU.dylib (??? - ???) <5EE0B644-FAD6-3E3C-A380-9B0CDA0B6432> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x979f0000 - 0x97a52ffb com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x97a6b000 - 0x97aa9fff libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <19174EC0-DE0F-38EA-B5F3-7580E84677DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x97b87000 - 0x97bbdff7 com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x97bbe000 - 0x97bbefff com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x97cb6000 - 0x97cb8ffb libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x98a0a000 - 0x98a27ff3 com.apple.openscripting (1.3.3 - ???) <33713C0B-B7D5-37AA-87DB-2727FDCC8007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x98a28000 - 0x98a48ff7 com.apple.RemoteViewServices (1.4 - 44.1) <1F831750-1E77-3013-B1A6-0DF528623790> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x98a49000 - 0x98aaaffb com.apple.audio.CoreAudio (4.0.2 - 4.0.2) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x98af1000 - 0x98b39ff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x98eb1000 - 0x98f71ffb com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x98f7e000 - 0x98f82ff3 libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
0x992ca000 - 0x992ceff7 com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x99d35000 - 0x99d78ffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
0x99da1000 - 0x99da1fff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib
0x99da2000 - 0x99e2ffe7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x99e30000 - 0x99e30ff0 com.apple.ApplicationServices (41 - 41) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9a0bf000 - 0x9a0d7ff7 libexpat.1.dylib (7.2.0 - compatibility 7.0.0) /usr/lib/libexpat.1.dylib
0x9a18f000 - 0x9a219ffb com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9a322000 - 0x9a412ff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
0x9a413000 - 0x9a4aaff3 com.apple.securityfoundation (5.0 - 55116) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9a4ab000 - 0x9a4adff9 com.apple.securityhi (4.0 - 1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9a4ae000 - 0x9a4b8ff2 com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9a4f0000 - 0x9a540ff8 libTIFF.dylib (??? - ???) <4DC2025D-15E7-35CA-B7C5-9F73B26C8B53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9a559000 - 0x9a575ffc libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9a5ce000 - 0x9a60eff7 libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
0x9a60f000 - 0x9aa84ff7 FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x9ab2d000 - 0x9ab38ffb com.apple.speech.recognition.framework (4.0.21 - 4.0.21) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9ad63000 - 0x9add7fff com.apple.CoreSymbolication (2.2 - 73.2) /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x9ae04000 - 0x9ae1affe libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib
0x9ae49000 - 0x9ae4dffa libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
0x9ae4e000 - 0x9ae7cfe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
0x9aea4000 - 0x9aeb2fff com.apple.opengl (1.7.7 - 1.7.7) <2D362F15-5EA6-37B6-9BCB-58F2C599ACDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9b291000 - 0x9b2b3ffe com.apple.framework.familycontrols (3.0 - 300) <5BCCDDC2-AFAC-3290-AEEF-23B2664CA11F> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x9b5c3000 - 0x9b5c9ffd com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9b5ca000 - 0x9b71cfff com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9b71d000 - 0x9b730ff8 com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9b793000 - 0x9b794ffd libCVMSPluginSupport.dylib (??? - ???) <22B85645-AA98-372B-BB55-55DCCF0EC716> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9b795000 - 0x9b7a3fff libz.1.dylib (1.2.5 - compatibility 1.0.0) /usr/lib/libz.1.dylib
0x9b7f5000 - 0x9b81effe com.apple.opencl (1.50.69 - 1.50.69) <2601993F-F3B3-3737-91AE-4A5795C52CD5> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9b81f000 - 0x9b89affb com.apple.ApplicationServices.ATS (317.11.0 - ???) <42238C8B-C93F-3369-A500-EC0F10EB2C80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9b89b000 - 0x9b8acfff libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
0x9b8ad000 - 0x9b8b0ffd libCoreVMClient.dylib (??? - ???) <361CCFAF-8565-383F-915F-0B059C793E42> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9b8ca000 - 0x9b923fff com.apple.HIServices (1.21 - ???) <5F4D3797-32E2-3709-85F4-4B56515A17D7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9b969000 - 0x9b96afff com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9b96b000 - 0x9bb63ff7 com.apple.CoreData (104.1 - 358.14) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9bc00000 - 0x9bc76fff com.apple.Metadata (10.7.0 - 627.32) <650EE880-1488-3DC6-963B-F3D6E043FFDC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9bc77000 - 0x9bc7fff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) /usr/lib/system/libcopyfile.dylib
0x9bc80000 - 0x9bd68fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib
0x9bd6a000 - 0x9bd8cff8 com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9bd8d000 - 0x9bd94ffd com.apple.NetFS (4.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x9bde7000 - 0x9beaafff com.apple.CoreServices.OSServices (478.46 - 478.46) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9beab000 - 0x9beb9ff7 libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
0x9beba000 - 0x9bec5fff libkxld.dylib (??? - ???) /usr/lib/system/libkxld.dylib
0x9bf0e000 - 0x9bf60ff7 libFontRegistry.dylib (??? - ???) <96E9602C-DFD3-3021-8090-60228CC80D26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9bf98000 - 0x9bfc7ff7 libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
0x9c022000 - 0x9c140fec com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9c141000 - 0x9c146ff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
0x9c147000 - 0x9c273ff9 com.apple.CFNetwork (520.4.3 - 520.4.3) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9c274000 - 0x9c2d9ff7 libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9c326000 - 0x9c351fff com.apple.GSS (2.2 - 2.0) <2C468B23-FA87-30B5-B9A6-8C5D1373AA30> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9c352000 - 0x9c392ff7 com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9c393000 - 0x9c3a0fff libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9c3ac000 - 0x9c3acfff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9c3ad000 - 0x9c4bdfe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
0x9c778000 - 0x9c794ff5 com.apple.GenerationalStorage (1.0 - 126.1) /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x9c795000 - 0x9c796fff liblangid.dylib (??? - ???) /usr/lib/liblangid.dylib
0x9c797000 - 0x9c83bfff com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9c83c000 - 0x9c845ff3 com.apple.CommonAuth (2.2 - 2.0) /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9caf7000 - 0x9cb05fff libdispatch.dylib (187.9.0 - compatibility 1.0.0) <2F918480-12C8-3F22-9B1A-9B2D76F6F4F5> /usr/lib/system/libdispatch.dylib
0x9cb3f000 - 0x9ce85ff3 com.apple.HIToolbox (1.9 - ???) <409E6397-0DCB-3431-9CCC-368317C62545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9ce91000 - 0x9ceecff3 com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 930
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=165.5M resident=54.6M(33%) swapped_out_or_unallocated=110.9M(67%)
Writable regions: Total=50.5M written=692K(1%) resident=1284K(2%) swapped_out=0K(0%) unallocated=49.3M(98%)
REGION TYPE VIRTUAL
CG shared images 128K
CoreGraphics 8K
MALLOC 40.2M
MALLOC guard page 32K
Stack 65.5M
VM_ALLOCATE 52K
__CI_BITMAP 80K
__DATA 8516K
__DATA/__OBJC 112K
__IMAGE 528K
__IMPORT 4K
__LINKEDIT 50.2M
__OBJC 1456K
__OBJC/__DATA 72K
__PAGEZERO 4K
__TEXT 115.3M
__UNICODE 544K
mapped file 140.2M
shared memory 312K
shared pmap 10.1M
TOTAL 433.1M
