Hi, I’m working on modding for an older game and would need access to FMOD Designer to achieve this. As I’ve read other posts of the same topic, I’ve gathered that you can request access. Hope to hear from you soon, thanks!
Access granted.
Hello Andrew, Thanks for granting access.
However, the specific guide I’m working with requires FMOD Designer v4.36.04. Is that available? The closest versions to this I see are 4.33.00 and 4.38.03, any help in finding the right version would be appreciated.
I can also try the steps with either of the other versions, but I’m unsure if it’d work.
4.36.04? Really? What guide is recommending that version?
It was a guide published in a discord server a few years ago, I think the channel it was in is still accessible but it doesn’t really matter nowadays. Although, after running some tests, 4.33.00 should work as well.
For what it’s worth, there appears to be an archive.org page for that version, though I cannot verify the integrity of the file(s) provided. It’s likely that the author of the guide found that installer archived and wrote the instructions based on that.
Anyways, thank you for your time.
