FMOD Studio Script to retrieve automation data
I’m trying to generate a .js script to retrieve the information of all the automations inside a FMOD Studio project. This is the script I’ve been working on, but I can’t seem to find the right data. I achieved to retrieve a list of all the events in the project, but then, I can’t find any more information. All the variables “automator”, “automationCurve”, and so on are empty, even if there are automations in my project.
Do someone know how could I retrieve the information of the automation curves/points, or at least, where is it stored or why are all those variables empty?
Thank you!
Script code:
studio.menu.addMenuItem({
    name: "Export Automation JSON",
    execute: function () {
        exportAutomationJSON();
function exportAutomationJSON() {
    var events = studio.project.model.Event.findInstances();
    if (!events || events.length === 0) {
        alert("No s'han trobat events al projecte");
        return;
    var data = {};
    events.forEach(function (event) {
        var eventData = {
            path: event.getPath(),
            automations: []
        function extractAutomationFrom(obj, label) {
            if (!obj || !obj.modulators) return;
            obj.modulators.forEach(function (modulator) {
                if (modulator.automation && modulator.automation.points.length > 0) {
                    var points = modulator.automation.points.map(function (pt) {
                        return {
                            time: pt.time,
                            value: pt.value
                    eventData.automations.push({
                        context: label,
                        modulatorType: modulator.type,
                        points: points
        function traverseTrack(track, pathLabel) {
            extractAutomationFrom(track.volume, pathLabel + " Volume");
            extractAutomationFrom(track.pitch, pathLabel + " Pitch");
            if (track.modules) {
                track.modules.forEach(function (module, i) {
                    // Nom de l'efecte
                    var modLabel = pathLabel + " > Effect[" + i + "] (" + module.name + ")";
                    extractAutomationFrom(module.volume, modLabel + " Volume");
                    extractAutomationFrom(module.pitch, modLabel + " Pitch");
                    // Altres propietats que podrien tenir moduladors
                    if (module.properties) {
                        Object.keys(module.properties).forEach(function (propName) {
                            var prop = module.properties[propName];
                            extractAutomationFrom(prop, modLabel + " Property: " + propName);
            if (track.children) {
                track.children.forEach(function (childTrack, i) {
                    traverseTrack(childTrack, pathLabel + " > SubTrack[" + i + "]");
        try {
            if (event.masterTrack) {
                traverseTrack(event.masterTrack, "MasterTrack");
        } catch (e) { alert(e); }
        if (eventData.automations.length > 0) {
            data[event.getPath()] = eventData;
    var json = JSON.stringify(data, null, 4);
    var outputPath = studio.project.filePath;
    if (!outputPath) {
        alert("No es pot determinar la ruta del projecte. Guarda el projecte abans d'executar.");
        return;
    outputPath = outputPath.replace(/\\/g, "/");
    outputPath = outputPath.substr(0, outputPath.lastIndexOf("/") + 1) + "automation_export.json";
    var textFile = studio.system.getFile(outputPath);
    if (!textFile.open(studio.system.openMode.WriteOnly)) {
        alert("No s'ha pogut obrir el fitxer per escriure.");
        return;
    textFile.writeText(json);
    textFile.close();
    alert("Exportació d'automatitzacions completada a:\n" + outputPath);
All property modulations for events belong to master/group tracks. Any automation applied to properties or modules on that track can be found in track.automationTracks[i]. You can find the following information for a given var automationTrack = track.automationTracks[i]:
  • The name of the property being automated is stored in automationTrack.automator.nameOfPropertyBeingAutomated
  • The object (i.e. module, effect, etc.) being automated is stored in automationTrack.automator.objectBeingAutomated
  • The points of the automation curve are stored as an array automationPoints belonging to the given automation curve - i.e. `automationTrack.automator.automationCurves[j]
For reference, the function .dump() can be used on all ManagedObjects in the Studio Scripting API, and will provide a list of all members for that object, which is helpful when writing scripts.
Okey, I know about the variable “track”, but I don’t know how to access it? Where do I find it? Is there a way to gather all the tracks?
I know events can be gathered like:
The problem is that the class Event does not have a track variable inside to then access track.automationTracks[i].
I hope you could answer my new question!
Thank you for your response, it was super useful!
The master track for an event can be found at event.masterTrack, and all other group tracks are stored in an array event.groupTracks[].
Okey, that solves everything!!
Thank you so much!!
