FMOD version 2.02 Unreal Engine 4.27 PS5 SDK 11.00 Request
Currently we are on FMOD version 2.02.16. Is it possible to get any support for PS5 SDK 11.00 for 2.02 in Unreal 4.27? It’s fine if we have to upgrade the minor version.
Thanks,
Paul
Hi Paul,
I have made FMOD 2.02.16 for UE4.27 with PS5 SDK 11.000 available on the downloads page.
Kind regards,
Morgan
Hello! @morgan_fmod
We are using FMOD 2.02.20. Is it also possible to add the PS5 SDK 11.000 compatibility here? thank you !
Hi Miguel,
I have made FMOD 2.02.20 for UE4.27 with PS5 SDK 11.000 available on the downloads page.
Kind regards,
Morgan
hey !
thank you @morgan_fmod
Is there a way to know which FMOD versions have SDK 11.000 compatibility from the downloads page in case we want to update to a newer version? where can I find this info on the documentation? that would be helpful, to double check before updating.
thank you again,
Mike
Hi Mike,
Unfortunately the only way I know of is to browse through each FMOD version using the version dropdown on the downloads page and check available SDKs in the table beneath.
However, I am able to provide a custom build of any FMOD version with the SDK version you need; feel free to post a thread on these forums at any time with your version requirements (FMOD version, UE version and SDK version) and I will respond as soon as possible :slight_smile:
Kind regards,
Morgan
okay, thank you. I cant seem to find the table with the info tho. I guess recent versions like 2.03.07, they already have this compatibility, right? I might just update to the latest FMOD version as a sanity check for the project.
Mike
Hi Mike,
If you visit the FMOD for Unreal Engine section of downloads page here, you can select an FMOD version using the dropdown box, and click the UE4 filter button to see the list of available FMOD for Unreal Engine 4.27 builds with that FMOD version:
If you then scroll down the list, you will see each of the PS5 builds we have available for that version of FMOD for Unreal Engine:
By doing this for each version of FMOD you are interested in, you can see which ones already have builds available for the PS5 SDK you require. As mentioned, you can also post a custom build request for any version of FMOD that doesn’t currently have PS5 11.000 available, and I would be more than happy to build and supply that to you.
Kind regards,
Morgan
Oh, I think I dont see that dropdown because I have to verify as developer for PS or something like that right?
I will investigate that further.
In the meanwhile, could you now activate FMOD 2.02.22 for UE5.4 with that PS5 SDK 11.000
Sorry for the back and forth, I was trying to understand how this works!
Again, thank you,
Mike
Hi Mike,
No problem! You can request console access via your profile page.
I have also made FMOD 2.02.22 for UE5.4 with PS5 11.000 available on the downloads page.
Please let me know if you have any more questions, I’m always happy to help.
Kind regards,
Morgan
Hello again,
It looks like I’ll need access to UE4.27 PS5 SDK 11.00 for FMOD version 2.02.29 whenever you get the chance.
Thank you!
Paul
Hi Paul,
I have made FMOD 2.02.29 for UE4.27 with PS5 SDK 11.000 available on the downloads page.
Kind regards,
Morgan
