How to cache a PARAMETER_ID of a global parameter
Hello!
I need to set a certain parameter every frame.
I assume that RuntimeManager.StudioSystem.setParameterByName() is less efficient than RuntimeManager.StudioSystem.setParameterByID()
Is that a correct assumption?
So how exactly can I get that id of a given parameter?
Thanks in advance :pray:
Correct, setParameterByID() is more efficient.
To get the id first we need to get the description of the parameter:
FMODUnity.RuntimeManager.StudioSystem.getParameterDescriptionByName("ParameterName", out FMOD.Studio.PARAMETER_DESCRIPTION parameterDescription);
The (FMOD Studio | Studio API) parameter description contains the id which you can access like so:
RuntimeManager.StudioSystem.setParameterByID(parameterDescription.id, newValue);
Exactly what I was asking, thanks a lot! :pray:
