How to set up FMOD Engine with Qt6 MinGW 64-bit
So I want to run my app inside of Qt Creator with relative set up path (with using $$PWD instead of "E:/) because I want to distribute my examples with included libs. For example, I can post my examples (ZIPs) on the forums and people can download it and run without set up of FMOD and so on. And without manual copying of fmod.dlll to the Debug folder. For a while the "E:/ method (absolute path) works without manual copying of fmod.dll but the $$PWD method (relative path) requires to copy fmod.dll to the Debug folder. The distribution of EXE is very clear for me. Yes, of course I should distribute fmod.dll, Qt6Core.dll and so on with EXE. My question about distribution of Qt project with libs to run it very quickly in Qt Creator on another computer.
The $$PWD method (relative path) allows to include all libs to a project. I should works like this - everyone can download the project and run it without downloading requires libs and without manual copying of fmod.dll to the Debug folder:
