[iOS] Problems with mixerSuspend and mixerResume
Thank you for sharing the detailed information and log output.
These log messages suggest that the DSP buffer size may be insufficient. Could you please try using System::setDSPBufferSize to configure the buffer size to (1024, 4) before initializing FMOD, and check if the issue persists?
Additionally, I found a related discussion that might be relevant to your case: Event callbacks don't work if other audio is playing on iOS - #4 by Leah_FMOD
