While integrating FMOD into our project at Salty Games, I created a property drawer to set up parameters in the property inspector, used like this:
public EventReference engineIdleEvent;
[LocalParamRef(nameof(engineIdleEvent))]
public string engineStateParam;
and this will give you a drop down of the available parameters for the event.
You only need two files:
LocalParamRefAttribute.cs in the game assembly
using UnityEngine;
public class LocalParamRefAttribute : PropertyAttribute
public LocalParamRefAttribute(string eventReferenceMemberName)
EventReferenceMemberName = eventReferenceMemberName;
public string EventReferenceMemberName { get; }
and LocalParamRefDrawer.cs in the editor assembly
using FMODUnity;
using System.Linq;
using UnityEditor;
using UnityEngine;
[CustomPropertyDrawer(typeof(LocalParamRefAttribute))]
public class LocalParamRefDrawer : PropertyDrawer
string[] choices;
string lastEventPath;
EditorEventRef editorEventRef;
bool invalid;
public override void OnGUI(Rect position, SerializedProperty property, GUIContent label)
var localParamRef = attribute as LocalParamRefAttribute;
if (property.propertyType != SerializedPropertyType.String)
Debug.LogError($"{nameof(LocalParamRefAttribute)} must be used on string fields");
int selectedIndex = -1;
var eventProperty = property.serializedObject.FindProperty(localParamRef.EventReferenceMemberName);
var eventPath = eventProperty.FindPropertyRelative("Path").stringValue;
if (editorEventRef == null || eventPath != lastEventPath)
editorEventRef = EventManager.EventFromPath(eventPath);
var choiceList = editorEventRef.LocalParameters.Select(p => p.Name).ToList();
selectedIndex = choiceList.IndexOf(property.stringValue);
// if the current value isn't in the list, add it first and select it to keep it.
if (selectedIndex < 0)
choiceList.Insert(0, property.stringValue);
selectedIndex = 0;
invalid = true;
choices = choiceList.ToArray();
EditorGUI.BeginProperty(position, label, property);
EditorGUI.BeginChangeCheck();
var choiceIndex = EditorGUI.Popup(position, label.text, selectedIndex, choices);
if (EditorGUI.EndChangeCheck())
selectedIndex = choiceIndex;
if (selectedIndex >= 0)
property.stringValue = choices[selectedIndex];
EditorGUI.EndProperty();
I will probably do another pass on this later but it works quite well now. Feel free to steal it FMOD folks ![]()
