Sending events to haptic/controller speaker Ports?
Is there a way to send and event to a port in the same way as to a regular bus? I want an event both to be audible and used as an haptic without having 2 events.
currently when trying to use a send from either an event or a mixer channel the ports does not show up as options to send to, just everything under the Master.
Is this something that will be introduced later or is the only way to having route events either to the regular channels or a port?
Yes, of course! You’ve already gotten most of the way there, in fact: Using a send is the right move. The only trick is that sends can only directly target return buses, and not other bus types; so you’ll need to create a return bus, route it into your port bus, and then create a send targeting that return bus.
Ahh right, of course! makes sense, thanks!
