UE Audio Component vs. FMOD Audio Component - Envelope Followers
Yes querying the bus metering info is a good approach. The process would be:
Now whenever you want to get the peak or rms levels you can use DSP::getMeteringInfo on that DSP object.
Hopefully that helps!
EDIT: I noticed someone else happens to be using this same approach for getting metering info, in case you need a code snippet to reference Clarification on how getMeteringInfo works
