About FMOD_INIT_THREAD_UNSAFE
When the Core thread safety is disabled with the FMOD_INIT_THREAD_UNSAFE flag and the funcForDifferentThread() is called “from different threads multiple times”, will the below pseudocode work?
class MySound {
	float curVol = 1.0f;
	MySound() {
		FMOD_System_PlaySound(TRUE);
		FMOD_Channel_SetVolume(curVol);
		FMOD_System_CreateDSPByType();
		FMOD_DSP_SetParameterFloat();
		FMOD_Channel_AddDSP();
		FMOD_Channel_SetPaused(FALSE);
	~MySound() {
		FMOD_Channel_Stop();
		FMOD_DSP_Release();
	bool decreaseVolume() {
		curVol -= 0.1f;
		if (curVol <= 0)
			return false;
		return true;
void funcForDifferentThread() {
	pthread_mutex_lock(&myMutex);
	MySound mySound = new MySound();
	soundList.add(mySound);
	pthread_mutex_unlock(myMutex);
void backgroundThreadFunc() {
	while (true) {
		foreach(each in soundList) {
			if (each->decreaseVolume() == false) {
				soundList.remove(each);
				delete(each);
		FMOD_System_Update();
		sleep(2000);
Yes, your pseudocode should work. As long as you are mindful of keeping calls from a single thread at a time, you should be okay. Information about thread safety can be found under White Papers | Threads and Thread Safety.
Hope this helps.
