JAVA
static {
System.loadLibrary("native-lib");
System.loadLibrary("fmod");
System.loadLibrary("fmodL");
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
TextView tv = (TextView) findViewById(R.id.sample_text);
org.fmod.FMOD.init(getApplicationContext());
org.fmod.AudioDevice.class.getResource("file:///storage/emulated/0/mp3.mp3");
tv.setText(stringFromJNI("file:///storage/emulated/0/mp3.mp3",2));
public native String stringFromJNI(String path, int type);
JAVA C++
Java_com_example_administrator_myapplication_MainActivity_stringFromJNI(
JNIEnv *env,
jobject /* this */, jstring path_, jint type) {
std::string hello = "Hello from C++";
const char *path = env->GetStringUTFChars(path_, NULL);
System *system = NULL;
Sound *sound = NULL;
Channel *channel = NULL;
DSP *dsp = NULL;
bool isPlaying = true;
float frequency;
//fmod初始化
System_Create(&system);
//指定最大的声轨数等参数
system->init(32, FMOD_INIT_NORMAL, NULL);
//创建声音对象
system->createSound(path, FMOD_DEFAULT, NULL, &sound);
switch (type) {
case TYPE_NORMAL:
//原声播放
//指定的是音轨0,最后update的时候才会播放
system->playSound(sound, 0, false, &channel);
break;
case TYPE_LUOLI:
//创建一个数字信号处理对象DSP
//DSP(数字信号处理)主要原理是:通过改变声音的两个参数:响度(振幅) 声调(频率)
system->createDSPByType(FMOD_DSP_TYPE_PITCHSHIFT, &dsp);
//设置参数,提高频率,升高一个八度
dsp->setParameterFloat(FMOD_DSP_PITCHSHIFT_PITCH, 2.5);
//把处理对象添加到Channel的音轨0中(注意这里要先播放然后添加音轨特效)
channel->addDSP(0, dsp);
LOGE("%s", "luo li");
break;
case TYPE_DASHU:
//创建一个数字信号处理对象DSP
//设置参数,提高频率,升高一个八度
dsp->setParameterFloat(FMOD_DSP_PITCHSHIFT_PITCH, 0.8);
LOGE("%s", "da shu");
break;
case TYPE_JINGSONG:
//惊悚
system->createDSPByType(FMOD_DSP_TYPE_TREMOLO, &dsp);
dsp->setParameterFloat(FMOD_DSP_TREMOLO_SKEW, 0.5);
break;
case TYPE_GAOGUAI:
//搞怪
//提高说话的速度
channel->getFrequency(&frequency);
frequency = frequency * 1.6;
channel->setFrequency(frequency);
LOGI("%s", "fix gaoguai");
break;
case TYPE_KONGLING:
//空灵
system->createDSPByType(FMOD_DSP_TYPE_ECHO, &dsp);
dsp->setParameterFloat(FMOD_DSP_ECHO_DELAY, 300);
dsp->setParameterFloat(FMOD_DSP_ECHO_FEEDBACK, 20);
LOGI("%s", "fix kongling");
break;
default:
break;
//update的时候才会播放
system->update();
//每秒钟判断一下是否在播放
while (isPlaying) {
channel->isPlaying(&isPlaying);
usleep(1 * 1000 * 1000);//单位是微妙,这里是1秒延时
//CMake默认支持异常处理。
//播放的时候可能会有异常,例如文件找不到等等,然后把异常抛给Java,这里就省略了
// try {
// } catch (...) {
//释放资源
sound->release();
system->close();
system->release();
return env->NewStringUTF(hello.c_str());
I cann’t hear the sound. Why???
