I ran a few input-output comparison tests, to make sure I understand the signal flow and how to set up events in Studio, and I’m seeing some unexpected things. Specifically:
If I open a blank project, create an event, place a stereo wav on track ‘Audio 1’ and then delete the ‘3D Panner’ effect, the output audio doesn’t match the input audio. The resulting audio is quieter (anywhere from 1-5dB) and it’s lacking bass it seems. To compare the the two files, after correcting the volume level of the recording from Studio, I mixed the source file with a phase inverted recording from Studio and they don’t cancel out.
I started this test because I wanted to make sure I understood the 3D Panner and how to make a 3D event sound identical to its source sound. When I struggled with that, I deleted the 3D Panner to see if I could make a simpler event sound identical to its source. I also ran this test with the ‘Timeline Loop Region’ event of the Examples project (using my samples) and got much more expected results (i.e. the two audio files sound sufficiently similar, even though the cancellation isn’t perfect). Also, to make sure my recording process wasn’t the problem, I ran the same test with Designer 2010 and I got near-perfect cancellation when mixing the source sound with the phase inverted recording from Designer. So it seems like there’s something in the default setup of the event in my project that’s changing the sound significantly. Any idea what I’m overlooking?
Additionally, I’m also seeing a 5-6dB drop in volume in the output of sounds located in a Scatterer module with the ‘Min & Max Scatter Distance’ set to 0.00 and 0.00 respectively. Is this volume drop simply the result of a sound using a surround pan (or am I missing something)? I’d like to be able to use the Scatterer (spawning) without it applying any Distance attenuation, but maybe those ‘Min & Max Scatter Distance’ settings aren’t correct for that desired result? I should mention that I’m also seeing a pretty hard pan to the right with these settings. Not sure if that’s the result of some auto-panning of the Scatterer (or maybe some settings that I screwed up). If it is auto-panning related, I’d like to be able to turn that off and either lock or automate the panning myself in some cases.
And, as mentioned above, I see a 1-5dB volume drop for sounds in a single sound or multisound module. Not sure if that’s normal.
Lastly, what 3D Panner settings will result in an output that perfectly matches the source audio? I believe this will come in handy when I want to use custom Distance attenuation curves or have a Scatterer that’s always/mostly 2D.
Sorry if I’ve overlooked something trivial or mucked something up in my test process.
Thanks,
Sean
