AudioClip.GetData Equivalent in FMOD?
Hi there :slightly_smiling_face:
I’m currently trying to convert a speech recognition solution work with FMOD audio, rather than the built-in Unity Audio. I’m stumped at a point in the script where the Unity method AudioClip.GetData is used to receive some data. I’m wondering if there is a way to extract the same data from FMOD sounds?
FMOD Help
I’m aware of a method called ReadData in FMOD, but I was, unfortunately, unable to apply it to get the desired values.
I’m a bit new to working this deeply with FMOD, so any help is appreciated :slightly_smiling_face:
There is a way to get the sample data from an audio source but there is a bit of setup to do, we will need to create a Sound to read the data from. Here is an example of how:
GetSampleData(string filePath)
    /// <summary>
    /// Return sample data in a byte array from an audio source using its file path
    /// </summary>
    /// <param name="filePath"></param>
    /// <returns></returns>
	private byte[] GetSampleData(string filePath)
        // Very useful tool for debugging FMOD function calls
        FMOD.RESULT result;
        // Sound variable to retrieve the sample data from
        FMOD.Sound sound;
        // Creating the sound using the file path of the audio source
        // Make sure to create the sound using the MODE.CREATESAMEPLE | MDOE.OPENONLY so the sample data can be retrieved
		result = FMODUnity.RuntimeManager.CoreSystem.createSound(filePath, FMOD.MODE.CREATESAMPLE | FMOD.MODE.OPENONLY, out sound);
        // Debug the results of the FMOD function call to make sure it got called properly
        if (result != FMOD.RESULT.OK)
            Debug.Log("Failed to create sound with the result of: " + result);
            return null;
        // Retrieving the length of the sound in milliseconds to size the arrays correctly
		result = sound.getLength(out uint length, FMOD.TIMEUNIT.MS);
            Debug.Log("Failed to retrieve the length of the sound with result: " + result);
            return null;
        // Buffer which the sample data will be copied too
        System.IntPtr buffer;
        // Creating a pointer to newly allocated memory
        // This pointer must be released at the end of the function!
        buffer = Marshal.AllocHGlobal((int)length * sizeof(byte));
        // Creating the return array which will have the sample data is a readable variable type
        // Using the length of the sound to create it to the right size
		byte[] byteArray = new byte[(int)length];
        // Retrieving the sample data to the pointer using the full length of the sound
		result = sound.readData(buffer, length, out uint read);
            Debug.Log("Failed to retrieve data from sound: " + result);
            return null;
        // Make sure the pointer has been populated
		if (_buffer != System.IntPtr.Zero)
            // Coping the data from our pointer to our usable array
			Marshal.Copy(buffer, byteArray, 0, (int)length);
        //Releasing the pointer
        Marshal.FreeHGlobal(buffer);
        //Returning the array populated with the sample data to be used
		return byteArray;
Hopefully, calling Sound::readData this way will get you the values you are looking for!
I have the exact same issue as the operator. I want to make use of the audioclip data in Unity, but with FMOD.
I want to use the audioclip’s data for the correct mouth synchronization in a dialogue system.
I have tried using your approach, which seems like the right approach
First of all, from which location do I get the file path? I’ve tried several file paths based on my folder structure already, but with no luck. What’s the correct path structure? Can you give me an example?
Also, I don’t seem to understand why your example requires a file path. Why not just use the event path instead to retrieve the audioclip?
I’ve also had a look at callbacks, and it seems to give me what I’m looking for, but it somehow only uses the master channel group. In my case I have a voice channel I wanna use. https://www.fmod.com/docs/2.02/unity/examples-dsp-capture.html
I think your documentation about how to implement this logic is kinda vague. It’s not really helping me.
Well I got your points here. Thanks for sharing
The file path I am using is: "C:\Users\XXX\Music\Epic SciFi Music.wav", but this was purely for the example. There are different ways to create a sound which can be found under FMOD API | Core API Reference.
In the example, as the DSP is being added to the MasterChannelGroup it is the only one that is needed but there are a number of ways to retrieve a channel. When referencing your voice channel could you elaborate on what it is? Could you screen shot it in your FMOD Studio Project?
Thanks for your quick apply. Much appreciated.
Oh, I had no idea that I needed the full path including the filename. Just wondering. Doesn’t this mess up the code if the game is being built?
And also, I can’t really see the benefits in this logic, because then I would have to somewhere store hundreds of paths of dialogue, which is basically already are stored in the FMOD project.
About DSP. Maybe I did it wrong. Still trying to get my head around it. I want to rule out all audio but keep the Voice for the facial animations, because I don’t want other background noise to interfere.
Maybe I need a different approach?
Again, this was just an example. Depending on where you are getting the audio source this will be different. E.g. Using an event.
Here is a reliable way to get the Voice Group from an Event Emitter. Make sure this is called after the event has started:
emitter = GetComponent<FMODUnity.StudioEventEmitter>();
if (emitter == null)
	return;
emitter.EventInstance.getChannelGroup(out FMOD.ChannelGroup masterChannelGroup);
masterChannelGroup.getGroup(0, out voiceGroup);
I am then attaching the DSP from the example to the voiceGroup.
Thanks for your reply, but it didn’t really help me.
Everything works perfectly on the masterchannel group, but I only want the “Voice” channel.
I’ve tried to get the channelgroup via the bus, based on the path to the voice channel. The Voice bus exists. I know that for a fact because I debugged it.
However, it wont allow me to add a DSP onto that channelgroup for some reason. The addDSP requires an index, but I’m kinda confused about which index it requires and what it’s for. I’ve tried several indexes like these [-3,-2,-1,0,1,2,30], but with the same outcome.
Apart from the Start function, I’ve also tried to add the DSP in runtime and while the NPC is talking, but it prints the same error.
So the issue with this method is that the channelGroup may not be ready when you are trying to assign the DSP to it. To resolve this we need to use a couple of commands:
bus.lockChannelGroup() will ensure that the channelGroup is created and will stay in memory, it will have to be unlocked in the future. (FMOD API | Studio API Reference)
FMODUnity.RuntimeManager.StudioSystem.flushCommands(); forces all commands to be called before continuing to ensure that the commands we are calling are being processed by the Studio System. (FMOD API | Studio API Reference).
FMODUnity.RuntimeManager.StudioSystem.flushSampleLoading() forces all sample loading and unloading to be completed so our calls can be run. (FMOD API | Studio API Reference)
if (FMODUnity.RuntimeManager.CoreSystem.getMasterChannelGroup(out currentMAster) == FMOD.RESULT.OK)
	FMODUnity.RuntimeManager.StudioSystem.getBus("bus:/In-World/Voice", out bus);
	bus.lockChannelGroup();
	FMODUnity.RuntimeManager.StudioSystem.flushSampleLoading();
	bus.getChannelGroup(out ChannelGroup group);
	if (FMODUnity.RuntimeManager.CoreSystem.createDSP(ref desc, out mCaptureDSP) == FMOD.RESULT.OK)
		if (!currentMAster.hasHandle())
			Debug.Log("No master");
			return;
		FMOD.RESULT result = currentMAster.addDSP(0, mCaptureDSP);
		Debug.Log(result.ToString());
			Debug.LogWarningFormat("FMOD: Unable to add mCaptureDSP to the master channel group");
		else
			success = true;
	else
		Debug.LogWarningFormat("FMOD: Unable to create a DSP: mCaptureDSP");
else
	Debug.LogWarningFormat("FMOD: Unable to create a GCHandle: mObjHandle");
Try updating your code with this, hope it helps!
Thanks for your reply! Unfortunately It’s still not working. I’m still always getting the master channel’s audio just like before and with no errors.
I’m wondering why you are assigning “group”, if it isn’t going to be used. I did try to replace “currentMaster” with “group” but then the debug warning error shows up again. (Recent screenshot)
Apologies for that, I have included the whole script without reference issues.
EventDataAndBus.txt (5.1 KB)
That works perfectly!
Thank you so much for your help!
is it possible to get Sound from bank instead of read it from disk? Can you please provide example?
I tried use event name as parameter, but it returns ERR_INVALID_PARAM.
result = FMODUnity.RuntimeManager.CoreSystem.createSound(@"event:/music/background", FMOD.MODE.CREATESAMPLE | FMOD.MODE.OPENONLY, out sound);
Second question is to sound.getLength() from example, where length is used to allocate space for sound data.
Is this valid only for one channel audio source?
Should it be multiply by channels numbers to allocate right space for all data, if sound is stereo?
Thanks for help
Milan
Unfortunately, it is not possible to get the sound from the bank. However, you can get the sound from the event using a callback: FMOD Engine | Studio API Reference - FMOD_STUDIO_EVENT_CALLBACK_SOUND_PLAYED. Let me know if this will work.
FMOD Engine | Core API Reference - System::createSound uses the path to an audio file, URL or a pointer to a preloaded sound memory. Unfortunately, you cannot use the Studio event path will not work.
What are you reserving the memory block for? FMOD Engine | Core API Reference - Sound::getLength will retrieve the length of the audio source in the provided time unit.
the reserved memory is for get audio data like audioClip.GetData(audioData, 0) in Unity.
According to documentation, the right format is FMOD.TIMEUNIT.PCMBYTES.
// Retrieving the bytes of the sound, related to PCM samples * channels * datawidth (ie 16bit = 2 bytes)
result = sound.getLength(out dataLength, FMOD.TIMEUNIT.PCMBYTES);
// This pointer must be released at the end of use
IntPtr data = Marshal.AllocHGlobal((int)dataLength * sizeof(byte));
result = sound.readData(data, dataLength, out uint read);
I tested to get audio data from callback, but without luck.
public static unsafe FMOD.RESULT DialogueEventCallback(FMOD.Studio.EVENT_CALLBACK_TYPE type, IntPtr instancePtr, IntPtr parameterPtr)
    switch (type)
        case FMOD.Studio.EVENT_CALLBACK_TYPE.SOUND_PLAYED:
			//1.create sound with constructor
			FMOD.Sound sound = new FMOD.Sound(parameterPtr);
			FMOD.RESULT result = sound.getLength(out uint dataLength, FMOD.TIMEUNIT.PCMBYTES);
			//2. create sound with createSound()
			FMOD.Sound sound2;
			FMOD.CREATESOUNDEXINFO exinfo = new FMOD.CREATESOUNDEXINFO();
			exinfo.cbsize = sizeof(FMOD.CREATESOUNDEXINFO);
			exinfo.length = dataLength;
			FMODUnity.RuntimeManager.CoreSystem.createSound(parameterPtr, FMOD.MODE.CREATESAMPLE | FMOD.MODE.OPENONLY | FMOD.MODE.OPENMEMORY_POINT, ref exinfo, out sound2);
            break;
    return FMOD.RESULT.OK;
  1. I create sound with constructor from parameterPtr, but readData() returns ERR_UNSUPPORTED
  2. When create sound with createSound() it throws errors and sound2 is null.
[FMOD] CodecOggVorbis::openInternal : failed to open as ogg
[FMOD] CodecMOD::openInternal : 'M.K.' etc ID check failed [????]
[FMOD] CodecS3M::openInternal : 'SCRM' ID check failed [
[FMOD] CodecXM::openInternal : 'Extended Module: ' ID check failed [`□??]
[FMOD] CodecIT::openInternal : 'IMPM' etc ID check failed [`□??]
[FMOD] CodecMIDI::openInternal : 'HThd' ID check failed [`□??]
[FMOD] CodecMPEG::openInternal : failed to open as mpeg
Can you please help me?
Thanks
Milan
Thank you for sharing the code.
What version of the integration are you using?
Would it be possible to elaborate on the expected behaviour?
The issue may be using a deprecated function, could you try something like this:
	// Retrieve the sound
	// Retrieve the length
	FMOD.RESULT result = sound.getLength(out uint length, FMOD.TIMEUNIT.PCMBYTES);
	if (result == FMOD.RESULT.OK)
		// Coonvert the length into bytes
		byte dataBytes = (byte)length;
		// Create the data arr
		byte[] data = new byte[dataBytes];
		result = sound.readData(data);
			Debug.Log("Read the data");
		else
			Debug.Log($"Failed to read data with: {result}");
The issue here is combining too many modes together. If you just use FMOD.MODE.OPENONLY you should be able to successfully create the sound.
FMODUnity.RuntimeManager.CoreSystem.createSound(data, FMOD.MODE.OPENONLY, ref exinfo, out sound2);
Hope this helps.
I have the same version as on yours screenshot and Unity6000.5.
Expected behaviour is get all audio data from played sound and use it as source for haptic feedback in our library. This already works from file, but better will be use it from event callback for better compatibility with PS5 behaviour and use bank event instead of file name.
I rewrited code according yours advice, but still not able to get audio data.
    switch (type)
			//1.get audio data from Sound created from parameterPtr and readData
				//IntPtr data = Marshal.AllocHGlobal((int)dataLength * sizeof(byte));
				//result = sound.readData(data, dataLength, out uint read);
				byte dataBytes = (byte)dataLength;
				Debug.Log($"readData result:{result}");
			//2. get audio data from Sound created by createSound() and readData
			result = sound.getFormat(out FMOD.SOUND_TYPE soundType, out FMOD.SOUND_FORMAT soundFormat, out int channels, out int bits);
			result = sound.getDefaults(out float frequency, out int priority);
			FMOD.Sound sound2;
			exinfo.format = soundFormat;
			exinfo.suggestedsoundtype = soundType;
			exinfo.numchannels = channels;
			exinfo.defaultfrequency = (int)frequency;
			result = FMODUnity.RuntimeManager.CoreSystem.createSound(parameterPtr, FMOD.MODE.OPENONLY, ref exinfo, out sound2);
			Debug.Log($"createSound result:{result}");
			//3. get audio data from Sound created from parameterPtr and access direct data by lock/unlock
			IntPtr dataZero = IntPtr.Zero;
			IntPtr dataNative = Marshal.AllocHGlobal((int)dataLength * sizeof(byte));
			result = sound.@lock(0, dataLength, out dataNative, out dataZero, out uint read, out uint length2);
			Debug.Log($"lock result:{result} read:{read}");
			result = sound.unlock(dataNative, dataZero, read, length2);
            break;
  1. sound.readData(data) return ERR_UNSUPPORTED
  2. createSound() return ERR_INTERNAL
  3. sound.@lock() return ERR_INVALID_PARAM
Info about sound from callback:
  • soundFormat - BITSTREAM
  • soundType - FSB
  • channels - 4
  • frequency - 48000
If I read audio data from file (wav/ogg) the info is:
  • soundFormat - PCM16/PCM16
  • soundType - WAV/OGGVORBIS
I tested both wav/ogg file as source for bank in Fmode Studio.
Milan
Thanks for the updated code.
Sorry, I am still a bit confused. You are creating a new sound from the sound that is being passed back from the callback? Does the original sound retrieved from FMOD.Sound sound = new FMOD.Sound(parameterPtr); not have the data you need?
Would something like this work?
public static FMOD.RESULT DialogueEventCallback(FMOD.Studio.EVENT_CALLBACK_TYPE type, IntPtr instancePtr, IntPtr parameterPtr)
	switch (type)
			FMOD.RESULT result = sound.getLength(out uint dataLength, FMOD.TIMEUNIT.MS); // <- Changed to the length of the audio in MS
				Debug.Log($"Failed to get length with result: {result}");
				return result;
				Debug.Log($"Failed to lock sound with result: {result}");
				return result;
			else
				Debug.Log($"Failed to get unlock sound with result: {result}");
				return result;
			break;
yes exactly.
Sound created from parameterPtr doesnt get the data. So I try different approach.
The code, which you posted, run without error. So the problem was in dataLength.
When I changed TIMEUNIT to RAWBYTES I am still able to read all bytes.
Which make sense because according to format BITSREAM FSB, TIMEUNIT.PCMBYTES returns different length.
Now is the question, what format has the data?
I need the data as source for WAVEFORMATEX.
Best
Milan
Hi, since Connor is away, I will be continuing the investigation.
Thank you for sharing the information.
From the information you provided:
it seems like you are requesting PCM16, so the format of the data would be PCM16, which is FMOD’s standard uncompressed format for working with audio data.
Hope this helps, let me know if you have any questions.
