Bulk Edit on Panner not working correctly
I’ve discovered the following: I was adding a Panner to a couple of events and wanted to set them all to stereo. The panner mode (dropdown) does not seem to allow bulk edit, whereas the stereo pan option does. This is annoying if you have a lot of events to edit.
Steps to reproduce:
-Create some events.
-Add a Paner to the Master.
-Select your events.
-Modify the panner-dropdown.
-observe: only the property of the highlighted event has changed.
-set the panner mode to “stereo”
-move the pan-knob
-observe: all of the evets have the selected pan-value
Cheers
Dominik
Tested with Fmod Studio 2.01.11
Thanks for letting us know about this issue! I’ll add it to our bug tracker now.
