I use the NX MoviePlayerSimple to play a webm movie ( video: VP8, audio: Vorbis) , it is working correctly, but after I linked FMOD lib and added some codes to create FMOD system, the audio decoder of Multimedia lib is not working correctly, I can hear many noise when playing the movie. The codes like below:
This is expected due to the issue you linked to, the fix for that will also be the fix for this.
The problem is that which ever lib gets loaded first (fmod or multimedia) has their lookup table loaded first, which stops the other from being loaded because they are named the same.
So the other case was:
load multimedia.nso
then load fmod
fmod doesn’t work
Now it’s the other way around, so similar results are expected:
