Capturing Unity game’s FMOD output (5.1 / Busses)
Thanks for your patience @xantomen and @dada_da.
The following DSPCaptureAndWrite script should serve as a straightforward example of how to accomplish what you want. It adds a capture DSP to a specified Bus’s underlying ChannelGroup (similar to our Unity DSP Capture example), and captures the audio data in memory. Then, on “R” being input, it will write the captured audio data to WAV file a specified file path and clear the audio data stored in memory.
DSPCaptureAndWrite.cs
using System;
using UnityEngine;
using System.Runtime.InteropServices;
using System.IO;
class DSPCaptureAndWrite : MonoBehaviour
    [SerializeField]
    private string mFilePath;
    [SerializeField]
    private string mBusPath;
    private FMOD.DSP_READ_CALLBACK mReadCallback;
    private GCHandle mObjHandle;
    private FMOD.DSP_DESCRIPTION mDSPDescription;
    private FMOD.DSP mDSP;
    private FMOD.ChannelGroup mCG;
    private List<float> mAudioData;
    private int mSampleRate;
    private int mNumChannels;
    private int mBitDepth = 32; // Assumes data will be 32 bit PCM Float, which it will automatically be in the FMOD Mixer graph
    private bool mDSPsCreated;
    private bool mRecording;
    private FileStream fs;
    private BinaryWriter bw;
    [AOT.MonoPInvokeCallback(typeof(FMOD.DSP_READ_CALLBACK))]
    static FMOD.RESULT CaptureDSPReadCallback(ref FMOD.DSP_STATE dsp_state, IntPtr inbuffer, IntPtr outbuffer, uint length, int inchannels, ref int outchannels)
        // Copy the input buffer to an intermediate buffer
        int lengthElements = (int)length * inchannels;
        float[] data = new float[lengthElements];
        Marshal.Copy(inbuffer, data, 0, lengthElements);
        // Get instance of DSPCaptureAndWrite from user data assigned to DSP
        FMOD.DSP_STATE_FUNCTIONS functions = (FMOD.DSP_STATE_FUNCTIONS)Marshal.PtrToStructure(dsp_state.functions, typeof(FMOD.DSP_STATE_FUNCTIONS));
        IntPtr userData;
        functions.getuserdata(ref dsp_state, out userData);
        if (userData != IntPtr.Zero)
            GCHandle objHandle = GCHandle.FromIntPtr(userData);
            DSPCaptureAndWrite obj = objHandle.Target as DSPCaptureAndWrite;
            // If currently recording, add buffer contents to recorded audio data
            if (obj.mRecording)
                obj.mNumChannels = inchannels;
                obj.mAudioData.AddRange(data);
        // Copy the input buffer to the output buffer so we can still hear it
        Marshal.Copy(data, 0, outbuffer, lengthElements);
        return FMOD.RESULT.OK;
    void Start()
        // Assign the DSP capture callback to a member variable to avoid garbage collection
        mReadCallback = CaptureDSPReadCallback;
        // Get DSP/Audio info and initialize list used to to store capture audio
        uint bufferLength;
        FMODUnity.RuntimeManager.CoreSystem.getDSPBufferSize(out _, out _);
        FMODUnity.RuntimeManager.CoreSystem.getSoftwareFormat(out mSampleRate, out _, out _);
        mAudioData = new();
        // Get a handle to this object to pass into the callback
        mObjHandle = GCHandle.Alloc(this, GCHandleType.Pinned);
        if (mObjHandle != null)
            // Define a basic DSP that receives a callback each mix to capture audio
            mDSPDescription = new FMOD.DSP_DESCRIPTION();
            mDSPDescription.numinputbuffers = 1;
            mDSPDescription.numoutputbuffers = 1;
            mDSPDescription.read = mReadCallback;
            mDSPDescription.userdata = GCHandle.ToIntPtr(mObjHandle);
        else
            Debug.LogWarningFormat("FMOD: Unable to create a GCHandle: mObjHandle");
        // Don't start recording until DSPs have been created
        mRecording = false;
        mDSPsCreated = false;
    void Update()
        // Bus' underlying ChannelGroup needs to be active before DSPs can be added
        if (!mDSPsCreated)
            FMOD.Studio.Bus bus = FMODUnity.RuntimeManager.GetBus(mBusPath);
            mRecording = AddDSP(bus);
            mDSPsCreated = mRecording;
            if (mRecording) Debug.Log("FMOD: Started capturing audio data");
        if (mDSPsCreated && mRecording)
            // When recording, press R to stop writing to file
            if (Input.GetKey(KeyCode.R))
                Debug.Log("FMOD: Stopped capturing audio data, writing audio to file at " + mFilePath);
                mRecording = false;
                fs = File.Create(mFilePath);
                bw = new BinaryWriter(fs);
                WriteWavHeader(mAudioData.Count);
                byte[] bytes = new byte[mAudioData.Count * 4];
                Buffer.BlockCopy(mAudioData.ToArray(), 0, bytes, 0, bytes.Length);
                fs.Write(bytes);
                fs.Close();
                bw.Close();
                mAudioData.Clear();
    bool AddDSP(FMOD.Studio.Bus bus)
        FMOD.DSP captureDSP = new FMOD.DSP();
        FMOD.ChannelGroup cg;
        if (bus.getChannelGroup(out cg) == FMOD.RESULT.OK)
            if (FMODUnity.RuntimeManager.CoreSystem.createDSP(ref mDSPDescription, out captureDSP) == FMOD.RESULT.OK)
                if (cg.addDSP(0, captureDSP) != FMOD.RESULT.OK)
                    Debug.LogWarningFormat("FMOD: Unable to add DSP to the bus' channel group");
                else
                    mDSP = captureDSP;
                    mCG = cg;
                    return true;
            else
                Debug.LogWarningFormat("FMOD: Unable to create a DSP");
        else
            Debug.LogWarningFormat("FMOD: Unable to get bus' channel group");
        captureDSP.release();
        return false;
    void RemoveDSP()
        // If the DSP is valid, remove it from the ChannelGroup and release
        if (mDSP.hasHandle())
            mCG.removeDSP(mDSP);
            mDSP.release();
    void OnDestroy()
            RemoveDSP();
            mObjHandle.Free();
    void WriteWavHeader(int length)
        bw.Seek(0, SeekOrigin.Begin);
        bw.Write(System.Text.Encoding.ASCII.GetBytes("RIFF"));      //RIFF                          4 bytes chars
        bw.Write(32 + length * 4 - 8);                              //File Size (after this chunk)  4 bytes int     (32 for rest of header + wave data)
        bw.Write(System.Text.Encoding.ASCII.GetBytes("WAVEfmt "));  //WAVEfmt                       8 bytes chars
        bw.Write(16);                                               //Length of above fmt data      4 bytes int
        bw.Write((short)3);                                         //Format 1 is PCM               2 bytes short
        bw.Write((short)mNumChannels);                              //Number of Channels            2 bytes short
        bw.Write(mSampleRate);                                      //Sample Rate                   4 bytes int
        bw.Write(mSampleRate * mBitDepth / 8 * mNumChannels);       //                              4 bytes int
        bw.Write((short)(mBitDepth / 8 * mNumChannels));            //                              2 bytes short
        bw.Write((short)mBitDepth);                                 //Bits per sample               2 bytes short
        bw.Write(System.Text.Encoding.ASCII.GetBytes("data"));      //data                          4 bytes chars
        bw.Write(length * 4);                                       //Size of data section          4 bytes int
Note that an instance of this class will only capture audio from a single bus. If you want to capture each of your three buses individually, you can just use three instances of this class and write the audio data to seperate WAV files.
If you want to capture and combine the audio from each of your buses, the script will require a little modification, but it should be as simple as placing an instance of the capture DSP on each bus, storing the captured audio data in three separate lists, and then summing each element of the three lists together before writing to file.
If you run into any issues using the script, please feel free to let me know.
