I am trying to change the pitch of an instance before and after the instance is called but I cannot really do it.
I don’t want to use parameter or snapshot but I want to change the pitch value via script and I want to do that real time so the instance will change pitch while playing.
I have tried the .setPitch(float) function for the instances but there is no change on the pitch when I pass positive numbers to the function. Also, if I pass negative values to the function it throws an assertion error. I checked the API and it is a range error.
Any ideas?
I am using Unity 2019.2.4f1 and FMOD Studio 2.01.04.
It sounds like what you need is indeed setPitch, keep in mind that function only accepts positive numbers. For instance a pitch of 2.0f is one octave up and a pitch of 0.5f is one octave down. As mentioned by @Paalo, a code example might highlight what your issue is.
