To handle such a large amount of banks, you’ll want to look into the Studio Scripting API and writing a custom script for creating your banks and audio tables based on the corresponding folders and assets.
Bank and Audio Table creation and assignment is fairly simple:
var bank = studio.project.create("Bank");
bank.name = "NewBank";
var table = studio.project.create("AudioTable")
table.name = "NewTable";
table.sourceDirectory = "Assets/AudioTableDirectory";
bank.audioTable = table;
The difficult part will be enumerating your folders. You can access an array of all assets in your project with studio.project.workspace.masterAssetFolder.assets
- unfortunately, these aren’t stored in the same hierarchy as they are shown in the Assets tab, so you’ll need to iterate through each asset and parse their assetPath
property. Alternatively, you may find it easier to use an external means (i.e. a scripting language with better filesystem access) to parse your directory and write your folders to a text file, open that text file with studio.system.getFile("./Your/TextFile/Path/Here.txt")
, and then parse each folder name/path to create your banks and audio tables.
I’d recommend taking a look at the Studio Scripting API Reference for more info. The .dump()
function is also extremely useful, as it will list all the functions, properties, and property values of any given ManagedObject
(i.e. any of the entities in your project).
