No worries Cameron,
It sometimes but not always crashes with:
[LOG] ProfileClient::markForDead : Closing client connection
[LOG] Thread::callback : FMOD profiler thread (recv) finished.
[LOG] Thread::callback : FMOD profiler thread (send) finished.
Full Log is below:
[LOG] System::create : Header version = 1.10.00. Current version = 1.10.00.
[LOG] SystemI::setOutputInternal : Setting output to type 0
[LOG] Manager::init : maxchannels = 1024 studioflags = 00000009 flags 00000000 extradriverdata 0000000000000000.
[LOG] SystemI::init : FMOD Studio Version: 00011000 (90329)
[LOG] SystemI::init : maxchannels = 1024, flags = 00030000, extradriverdata = 0000000000000000
[LOG] SystemI::setOutputInternal : Setting output to type 8
[LOG] OutputWASAPI::init : Mix Format (WAVEFORMATEX): wFormatTag=0xFFFE, nChannels=8, nSamplesPerSec=48000, nAvgBytesPerSec=1536000, nBlockAlign=32, wBitsPerSample=32, cbSize=22.
[LOG] OutputWASAPI::init : Mix Format (WAVEFORMATEXTENSIBLE): wValidBitsPerSample=32, dwChannelMask=0x0000063F, SubFormat=00000003-0000-0010-8000-00AA00389B71.
[LOG] OutputWASAPI::init : Output buffer size: 4096 samples, latency: 0.00ms, period: 10.00ms, DSP buffer: 1024 * 4
[LOG] SystemI::init : Create master channel group and master sound group.
[LOG] DownMix::init : dspbuffersize: 1024 rate: 48000. output speaker mode: 7, input speaker mode 3
[LOG] DownMix::init : done.
[LOG] SystemI::init : Set up emulated output. 1024 channels
[LOG] SystemI::init : create the channel pool
[LOG] SystemI::init : create the stream thread
[LOG] Thread::initThread : Init FMOD stream thread. Priority: 2, Stack Size: 65536, Semaphore: No, Sleep Time: 10, Looping: Yes.
[LOG] SystemI::DSPCodecPoolRegister : register codec pool for pool type 5
[LOG] Thread::initThread : Init FMOD mixer thread. Priority: 3, Stack Size: 49152, Semaphore: No, Sleep Time: 0, Looping: Yes.
[LOG] AsyncManager::init : manager 000000004D98E528 isAsync 1 updatePeriod 0.02
[LOG] Thread::initThread : Init FMOD Studio update thread. Priority: 0, Stack Size: 65536, Semaphore: No, Sleep Time: 1, Looping: No.
[LOG] AsyncManager::init : done
[LOG] PlaybackSystem::init :
[LOG] Thread::initThread : Init FMOD Studio sample load thread. Priority: 0, Stack Size: 65536, Semaphore: No, Sleep Time: 1, Looping: No.
[LOG] PlaybackSystem::init : done
[LOG] LiveUpdate::init :
[LOG] Thread::initThread : Init FMOD Studio bank load thread. Priority: 0, Stack Size: 65536, Semaphore: No, Sleep Time: 1, Looping: No.
[LOG] Manager::init : done.
[LOG] Profile::init : Profiler listening on port: 9264
[LOG] Manager::readBank : fileversion = 99, compatVersion = 99 (oldest = 44, newest = 99)
[LOG] PlaybackSystem::acquireMasterBus : Setting master channel group format to 6
[LOG] Thread::initThread : Init FMOD profiler thread (recv). Priority: 0, Stack Size: 131072, Semaphore: No, Sleep Time: 0, Looping: No.
[LOG] Thread::initThread : Init FMOD profiler thread (send). Priority: 0, Stack Size: 131072, Semaphore: No, Sleep Time: 0, Looping: No.
[LOG] LiveUpdate::clientConnected : client = 0000000011BA6328
[LOG] SystemI::createSoundInternal : filename = : mode 02000202
[LOG] SystemI::createSoundInternal : exinfo->cbsize = 232
[LOG] SystemI::createSoundInternal : exinfo->length = 43606784
[LOG] SystemI::createSoundInternal : exinfo->fileoffset = 3972512
[LOG] SystemI::createSoundInternal : exinfo->numsubsounds = 1
[LOG] SystemI::createSoundInternal : exinfo->inclusionlist = 00000000733BF5FC
[LOG] SystemI::createSoundInternal : exinfo->inclusionlistnum = 1
[LOG] SystemI::createSoundInternal : exinfo->suggestedsoundtype = 5
[LOG] SystemI::createSoundInternal : exinfo->useropen = 00007FFEF1665C70
[LOG] SystemI::createSoundInternal : exinfo->userclose = 00007FFEF1665C40
[LOG] SystemI::createSoundInternal : exinfo->userread = 00007FFEF1665D40
[LOG] SystemI::createSoundInternal : exinfo->userseek = 00007FFEF1665DF0
[LOG] SystemI::createSoundInternal : exinfo->fileuserdata = 000000005F548978
[LOG] SystemI::createSoundInternal : exinfo->initialseekpostype = 1
[LOG] SystemI::createSoundInternal : Format has 1 subsounds.
[LOG] SystemI::createSoundInternal : Create as FMOD_CREATESAMPLE
[LOG] SystemI::createSoundInternal : Multi-sample sound (1 subsounds), create a sample container.
[LOG] SystemI::createSoundInternal : creating subsound 0/1
[LOG] SystemI::createSample : mode 02000202 length 275375 samples, lengthbytes 60128
[LOG] SystemI::createSample : channels = 2
[LOG] SystemI::createSample : output = 00000000669DA078
[LOG] OutputSoftware::createSample : lengthpcm 275375, lengthbytes 60128, channels 2, format 2, freq 48000, mode 0200020a
[LOG] SystemI::createSoundInternal : No name found in file, use filename.
[LOG] SystemI::createSoundInternal : done. OpenState now = FMOD_OPENSTATE_READY.
[LOG] SystemI::createSound : filename = **************************************************************************/Master Bank.bank : mode 02010082
[LOG] SystemI::createSound : FMOD_NONBLOCKING specified. Putting into queue to be opened asynchronously!
[LOG] Thread::initThread : Init FMOD nonblocking thread (0). Priority: 1, Stack Size: 81920, Semaphore: Yes, Sleep Time: 0, Looping: Yes.
[LOG] SystemI::createSound : setdata soundi = 000000004E654CA8 : node = 0000000060052AD0
[LOG] SystemI::createSound : add node to async list : head = 000000004E3FA058. list count = 0
[LOG] AsyncThread::threadFunc : Starting Asynchronous operation on sound 000000004E654CA8
[LOG] SystemI::createSoundInternal : filename = **************************************************************************/Master Bank.bank : mode 02010082
[LOG] SystemI::createSoundInternal : exinfo->inclusionlist = 0000000060052BE8
[LOG] SystemI::createSoundInternal : Create as FMOD_CREATESTREAM
[LOG] System::createSoundInternal : decode buffersize = 19200 : blocksize = 256 : format = 2
[LOG] SystemI::createSample : mode 02010082 length 19200 samples, lengthbytes 153952
[LOG] OutputSoftware::createSample : lengthpcm 19200, lengthbytes 153952, channels 2, format 2, freq 48000, mode 0201008a
[LOG] System::createSoundInternal : 1 subsounds detected.
[LOG] System::createSoundInternal : Seek stream to start
[LOG] System::createSoundInternal : flush stream buffer
[LOG] System::createSoundInternal : flush successful.
[LOG] System::createSoundInternal : switch file handle from small blocking single buffered to large nonblocking doublebuffered.
[LOG] Thread::initThread : Init FMOD file thread. Priority: 1, Stack Size: 16384, Semaphore: No, Sleep Time: 10, Looping: Yes.
[LOG] AsyncThread::threadFunc : Finished Asynchronous operation on sound 000000004E654CA8
[LOG] SoundI::getSubSound : sound 000000004E654CA8. Subsound index 0 / 1
[LOG] SystemI::createSoundInternal : exinfo->fileuserdata = 000000005F543F18
[LOG] SystemI::createSample : mode 02000202 length 15048 samples, lengthbytes 4608
[LOG] OutputSoftware::createSample : lengthpcm 15048, lengthbytes 4608, channels 2, format 2, freq 48000, mode 0200020a
[LOG] SystemI::createSample : mode 02000202 length 15604 samples, lengthbytes 4768
[LOG] OutputSoftware::createSample : lengthpcm 15604, lengthbytes 4768, channels 2, format 2, freq 48000, mode 0200020a
[LOG] SystemI::createSample : mode 02000202 length 16459 samples, lengthbytes 4896
[LOG] OutputSoftware::createSample : lengthpcm 16459, lengthbytes 4896, channels 2, format 2, freq 48000, mode 0200020a
[LOG] SystemI::createSample : mode 02000202 length 16225 samples, lengthbytes 3840
[LOG] OutputSoftware::createSample : lengthpcm 16225, lengthbytes 3840, channels 2, format 2, freq 48000, mode 0200020a
[LOG] SystemI::createSample : mode 02000202 length 13386 samples, lengthbytes 4224
[LOG] OutputSoftware::createSample : lengthpcm 13386, lengthbytes 4224, channels 2, format 2, freq 48000, mode 0200020a
[LOG] SystemI::createSoundInternal : exinfo->fileuserdata = 000000005F5491F8
[LOG] SystemI::createSample : mode 02000202 length 11377 samples, lengthbytes 2912
[LOG] OutputSoftware::createSample : lengthpcm 11377, lengthbytes 2912, channels 2, format 2, freq 48000, mode 0200020a
[LOG] SystemI::createSoundInternal : exinfo->fileuserdata = 000000005F558658
[LOG] SystemI::createSample : mode 02000202 length 26759 samples, lengthbytes 5952
[LOG] OutputSoftware::createSample : lengthpcm 26759, lengthbytes 5952, channels 2, format 2, freq 48000, mode 0200020a
[LOG] SystemI::createSound : setdata soundi = 000000004E655368 : node = 0000000011BCEF20
[LOG] AsyncThread::threadFunc : Starting Asynchronous operation on sound 000000004E655368
[LOG] SystemI::createSoundInternal : exinfo->inclusionlist = 0000000011BCF038
[LOG] SystemI::createSample : mode 02010082 length 19200 samples, lengthbytes 1265696
[LOG] OutputSoftware::createSample : lengthpcm 19200, lengthbytes 1265696, channels 2, format 2, freq 48000, mode 0201008a
[LOG] AsyncThread::threadFunc : Finished Asynchronous operation on sound 000000004E655368
[LOG] SoundI::getSubSound : sound 000000004E655368. Subsound index 0 / 1
[LOG] SoundI::release : BassFaceIntro (000000004E654CA8)
[LOG] SoundI::release : remove stream samples. (000000004E654CA8)
[LOG] SoundI::release : BassFaceIntro (000000004E3F96E8)
[LOG] SoundI::release : done
[LOG] SoundI::release : release subsounds. (000000004E654CA8)
[LOG] SoundI::release : BassFaceIntro (000000004E654288)
[LOG] SoundI::release : release codec. (000000004E654CA8)
[LOG] SoundI::release : BassFaceLoop (000000004E655368)
[ERR] ProfileClient::recvThreadLoopFunction : Recv thread loop returned 16
