Feature request: Solo and mute event from Event Editor window
It would be really handy if we could solo and mute events from the Event Editor window, instead of having to go to the profiler, start a capture, find the track and press solo or mute, which is often quite awkward. This is small thing I really miss from Wwise, and it seems like FMOD already supports it, the buttons are just really hard to get to :grinning_face_with_smiling_eyes:
+1 to this!!
It’s either going through the profiler or the mix window to solo the bus - especially time consuming when trying to isolate sounds in events that share mix groups, since you need to go into each event you don’t want to hear and mute out each individual audio track.
Now that you mention it, I can see how being able to mute and solo events from the event editor window could be useful. I’ll add it to our feature and improvement tracker.
