Fmod 4.32.04
Hello
I really wanted to make a mod for a Witcher 2, but according to the modding guide, I should be using 4.32.04 version of FMOD and it’s nowhere to be found. I saw a couple of posts about it here and I wonder if it’s still possible to gain access to this older versions. I’d really apprecieate any help or information at least.
Access granted.
Thank you so much!!!
I would also like an older version of the FMOD designer, for Crysis 1. Something doesn’t work with the latest version, I’ve tried everything. yes i’m crazy)
Access granted.
I am also working on an audio mod and need access to fmod 4.32.04. Would you please make that available? Thank you!
Access granted.
I would also want the old version of FMOD designer, for Crysis 2. Something doesn’t work with the latest version, I’ve tried everything. I’m starting to give up now
Access granted.
I would also want the old version of fmod designer, for OFP2: DR. Something doesn’t work with the latest version, I’ve tried everything. I’m starting to give up now. Could you give me the version of 4.20+ or 4.25+?
karldoenitz - the designer downloads are public right at the bottom of the download page.
